Routing over a trunk
Patrick Evans
I have a packet tracer lab that i am using to learn my CCNA on.
I have 2 sites connected together by layer 3 switches and i cannot ping between the sites.
The trunk is vlan10 with addresses on each side of 1.1.1.1/30 and 1.1.1.2/30
From each switch i can ping the other side.
I have some machines on 192.168.100.0/24 in Vlan 20
and machines on the other switch on 10.0.10.0/25 Vlan 30
From Vlan20 i can ping the local side of Vlan 10 and the same from Vlan 30 but i cant ping over the trunk.
Can anyone give me a hint as to why not?
SWITCH 1
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname ScunthorpeSwitch
enable secret 5 *****
ip routing
interface FastEthernet0/1
interface FastEthernet0/2
 switchport access vlan 20
 switchport mode access
interface FastEthernet0/3
 switchport access vlan 30
interface FastEthernet0/24
 switchport access vlan 10
 switchport mode trunk
interface Vlan1
 no ip address
interface Vlan10
 ip address 1.1.1.2 255.255.255.252
interface Vlan30
 ip address 10.0.10.253 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/24
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/4, Fa0/5, Fa0/6
                                                Fa0/7, Fa0/8, Fa0/9, Fa0/10
                                                Fa0/11, Fa0/12, Fa0/13, Fa0/14
                                                Fa0/15, Fa0/16, Fa0/17, Fa0/18
                                                Fa0/19, Fa0/20, Fa0/21, Fa0/22
                                                Fa0/23, Gig0/1, Gig0/2
10   FIRBELINK                        active
20   SHEFFIELD                        active    Fa0/2
30   SCUNTHORPE                       active    Fa0/3
40   SERVERS                          active
1002 fddi-default                     act/unsup
ScunthorpeSwitch#sho interfaces trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/24      on           802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/24      1-1005
Port        Vlans allowed and active in management domain
Fa0/24      1,10,20,30,40
Port        Vlans in spanning tree forwarding state and not pruned
SWITCH 2
version 12.2
hostname "Sheffield Switch"
enable secret 5 **************
ip routing
username ***** password 0 ********
no ip domain-lookup
 shutdown
 description FIBER BETWEEN SITES
 no switchport
 no ip address
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan10
 ip address 1.1.1.1 255.255.255.252
interface Vlan20
 ip address 192.168.100.250 255.255.255.0
ip classless
banner motd ^C
******* , Do Not Enter ******   ^C
1    default                          active    Fa0/3, Fa0/4, Fa0/5, Fa0/6
10   FIRBELINK                        active
20   SHEFFIELD                        active    Fa0/1, Fa0/2
40   SERVERS                          active
Sheffield Switch#sho interfaces trunk
Fa0/24      1-1005
Fa0/24      1
Marvin Rhoads
You have no routing protocol running so the L3 switches only know about connected and static routes. The only static route you have is the default:
The interface you tell it to use is a L2 interface, so you're effectively not routing with that default. If you create an SVI (Layer 3 switched virtual interface) for each VLAN on all the switches (i.e. add interfaces for VLAN 20 on switch 1 and VLAN 30 on switch 2), it will work. also if you made the default route on each switch be the other switch's VLAN 10 L3 interface, that would also work.
You could also setup actual routing like OSPF or EIGRP but that's outside the scope for CCNA practice.
Marvin Rhoads
HI Marvin,  I tried both methods out and they both work.  I may have made my switches VTP transparent earlier on.  I guess if I didnt then this problem wouldn't have occurred as all the Vlans would be in place?
Actually I believe that EIGRP and OSPF are both on the new CCNA, but I wont come through to that module for another couple of weeks.
Thanks for your help.
Patrick
