Routing past VPN client
StanDamen
Hi Guys,
I need some serious help again. Im testing a way to route after a client.
I could try explain this for 3 pages, but this drawing should make it easier to understand.
Ping from 10.5.0.1 to 10.4.0.1 (Green line) Works!
Ping from 10.5.0.1 to 172.17.0.1 or 172.17.0.2 (Red line) DOES NOT WORK.
Im using the Windows XP desktop with 2 network cards as a router.
I have included the config of the Cisco Router below.
If anything else is needed or needs clarification please ask.
I dont really understand why it doesnt work.
One last note: I CAN ping 172.17.0.2 from the Cisco Router!, so i think it should work from 10.5.0.1 aswell but it doesnt.
Can anyone help?
Kevin Morales
Hello, you have enter the command "reverse-route" in the crypto map.
crypto dynamic-map customerHQmap 1
set transform-set security
reverse-route
crypto dynamic-map customermap 1
reverse-route
