Routing Question About Load Sharing
scooter817
Level 7
Level 7
Hi Everyone
I was asked a question by a former coworker and I don't know the answer to this, can someone tell me what would I do to make this work in an enterprise environment. THanks in advance and have a great day and I look forward to the response to the question.
“Consider an environment with 2 Internet circuits from different ISPs with different bandwidths. How and what would you do to set them up in load sharing mode with the circuit having more bandwidth routing more data?”
shanilkumar2003
Level 5
Level 5
You can use PBR, NAT with route-map to achieve the same
Shanil
Rasika Nayanajith
You need to clarify how is the routing configured this environment to two different ISP ? Depend on that answer may be vary. Get more clarity on that and ask what dynamic routing protocols configuration we can assume to give an answer
Rasika
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
For egress, if supported on the box, I would use OER or PfR.
shanilkumar2003
Level 5
Level 5
Shanil
