Routing to two ISP's with one L3 switch - using route-maps
roliveira11
Hello Cisco Community! I have a 3750 acting as WAN switch connected to CrownCastle and MetTel
I was able to get the routing up for the CrownCastle side as that circuit was available/installed first..so the default route that's configured routes to Crown currently.... now that MetTel has been installed, I'd like to carve out a few ports on the 3750 for MetTel and route it's respective public LAN IP's out to MetTel.
vlan 222 - MetTel LAN
vlan 444 - MetTel WAN
Is it possible to configure a routemap for just the 2nd ISP to be used? What am I missing? I configured an ACL, a route map, and applied the route-map to the vlan interface. I must be missing something silly! Please help! Thank you!
Configuration is below!:
interface FastEthernet0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
switchport access vlan 333
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
switchport access vlan 50
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
switchport access vlan 222
interface GigabitEthernet1/0/14
switchport access vlan 444
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
description ToCrownModem
switchport access vlan 777
interface GigabitEthernet1/1/1
speed nonegotiate
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
switchport mode access
speed nonegotiate
interface TenGigabitEthernet1/1/2
interface Vlan1
no ip address
shutdown
interface Vlan50
description AryakaTransitVLAN
no ip address
interface Vlan222
description MetTelLAN
ip address x.x.x.123 255.255.255.248
interface Vlan333
description CrownCastleLAN
ip address x.x.x.33 255.255.255.240
interface Vlan444
description MetTelWAN
ip address x.x.x.30 255.255.255.252
interface Vlan777
description CrownCastleWAN
ip address x.x.x.146 255.255.255.252
ip route 0.0.0.0 0.0.0.0 x.x.x.145
access-list 110 permit ip 1.1.1.0 0.0.0.255 any
route-map To-MetTelWAN permit 10
match ip address 110
set ip next-hop 1.1.1.29
19 Replies 19
Hi Paul, THanks for the reply! Maybe you did not catch my previous posts of my CLI output- but I was showing that I was going into the L3 interface, applying the ip policy route-map command, the switch taking it, but when looking at the running-configration for the L3 interface, it did not show the ip policy route-map statement applied - I do still need to look at the show sdm prefer output as well as try the "set ip DEFAULT next hop x.x.x.x" command
Thank you all so much for the collabaration! I'll be providing my findings tomorrow morning again and pick back up!
Hello
FYI - set ip DEFAULT next hop x.x.x. , This will check the route table for any entries for the nexhop address and if there are entries then no policy routing is applied , normal routing will take precedence.
So if it hasn't worked with set ip next hop x.x.x. then it shouldn't work changing it to  set ip DEFAULT next hop x.x.x.
At this time I would say the switch is running the wrong SDM template as a possible cause to why PBR isn't working, So suggest to change to it routing/ ipv4-ipv6 routing ,reload the switch (when applicable) and test again
Kind Regards
Paul
not sure if this has already been mentioned, but you also need to run the IP Services feature pack, in addition to 'sdm prefer routing'. Check with 'show license' which feature pack is activated...
Hi Georg! IPServices is enabled! Thanks for asking! Based on everyone's feedback, It sounds like the next best course of active is to configure the "sdm prefer routing" command, wr mem, and reload the switch.
HaemoWANswitch#show license
Index 1 Feature: ipservices
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
License Count: Non-Counted
Index 2 Feature: ipbase
Period left: 8 weeks 4 days
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 3 Feature: lanbase
Period left: 0 minute 0 second
HaemoWANswitch#
I don't want to add anything redundant, but below is the link to the guidelines. You need IP Services, sdm prefer routing, and there is also somethig mentioned about PBR not wiorking when IPv4 and IPv6 traffic is being processed. I am not sure what the latter means exactly, so don't enable IPv6, to be safe.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750e_3560e/software/release/12-2_55_se/configuration/guide/3750escg/swiprout.html#wp1228588
