Routing using FastEthernet
shoddy1988
Community Member
I have a 2801 router and i am having trouble routing the 2 fast ethernet ports.
From the router i can ping the gateway 203.25.120.4 and the host machine 10.0.0.1 but i can't ping the gateway from the host machine.
The host machine is set with the ip 10.0.0.1 255.0.0.0 10.0.0.254
Can someone please tell me what i have done wrong?
Thanks in advance
below is the config of the router
Current configuration : 755 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
interface FastEthernet0/0
ip address 203.25.120.202 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.0.254 255.0.0.0
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 203.25.120.4
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Hi Brendon,
aaah I see.
Well, does the router (gateway) with IP address 203.25.120.4 know how to get back to the 10.x.x.x network? Have you tried examine the routing table there with command show ip route ?
My best guess here is that when you do ping from the router with no source IP address specified, the source address is 203.25.120.202 and that's why the ping makes it back to the 2801 router - It knows how to get to the 203.25.120.x /24 network because it is indeed directly connected.
So my suggestion is this:
try to ping 203.25.120.204 source 10.0.0.254 from your 2801 router
If it fails - make sure that 10.x.x.x /8 network is in the routing table of your gateway (the one with IP address 203.25.120.4)
If it is there - make sure it points to your 2801 router
Best regards,
Jan
6 Replies 6
Jan Hrnko
Level 9
Level 9
Hi Brendon,
which gateway can't you ping from the host?
203.25.120.202 or the local gateway for the host which is 10.0.0.254?
Because host should be able to ping 10.0.0.254 with no problem at all. In that case, the router is configured correctly, I suggest that the problem is at the host machine.
Best regards,
Jan
Hi Jan
I can ping 10.0.0.254 from the host and i can ping 203.25.120.202 from the host as well.
I just can't get to the other side which is the 203.25.120.4 which is my default gateway for the rest of the network.
From the router i can ping 203.25.120.4 so i know that it is active and works.
Thanks Brendon
  what is the device at 203.25.120.4  ?
Hi Brendon,
aaah I see.
Best regards,
Jan
Hi Jan
That was indeed my problem
Thank you very much for your help
Brendon
Hi Brendon,
I'm happy to hear that, you're welcome!
Best regards,
Jan
