Routing VLAN
skiver
Community Member
Is there a problem with running an IP address on the main interface with sub-interfaces for Vlans or should the IP addresses all be sub-interfaces?
EXAMPLE:
interface GigabitEthernet0/0
ip address 172.16.1.2 255.255.0.0
bridge-group 1
media-type rj45
interface GigabitEthernet0/0.1
encapsulation dot1Q 11
ip address 192.168.11.254 255.255.255.0
no cdp enable
interface GigabitEthernet0/0.3
encapsulation dot1Q 33
ip address 192.168.33.254 255.255.255.0
no cdp enable
or
no ip address
media-type rj45
bridge-group 1
interface GigabitEthernet0/0.2
no cdp enable
no cdp enable
What would the repercusions be?
Both seem to work the same.
Pavel Bykov
Level 10
Level 10
The big difference is that packets traveling from "interface GigabitEthernet0/0 " are not send encapsulated. They don't have 802.1Q tags, and therefore do not belong to any VLAN. They will be received by either NATIVE VLAN on other side (if it's a switch with trunk port), or interface that has no encapsulation on another side (if it's a router).
In second configuration you are throwing two IP networks in one VLAN (172.16.1.2 255.255.0.0 and 192.168.11.254 255.255.255.0 )
Not that it won't work, but it's not recommended and is not a good design practice. You are creating VLANs to separate broadcast domains, and create separate networks, but here you have two networks in one VLAN - VLAN 11
Where does bridge-group 1 lead to?
Jagdeep Gambhir
Level 11
Level 11
Both configs are ok , it will work fine.
~JG
Pavel Bykov
Level 10
Level 10
good catch but the 172.16.x.x is supposed to be in vlan 1 (typo) sorry.
The bridge-group is over a serial link.
