Routing with Multiple FE interfaces
Matt.Fields
I have a Cisco 2811 that has 2 Fast Ethernet interfaces. One interface
I want to use to control "Routes" on my local private network
(Basically just routing back throught same same interface).
The other Interface is the LAN side my T1 connection coming in on a WIC
card (WAN).
My issue is that I can only specifly one default-gateway and one
0.0.0.0 0
0.0.0 route for the router.
Ideally, I need to be able to route and specify gateway settings by
interface.
Is this possible?
Collin Clark
You only need one default route (pointing towards your internet connection), all other routes will be directly connected through your FE interface, or you'll have to create static routes/routing protocol for your other internal networks.
This is currently how it looks:
interface Multilink1
ip address 67.xxx.xxx.126 255.255.255.252
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface Serial0/0/0
description Quest Internet T1
no ip address
encapsulation ppp
no keepalive
no fair-queue
ppp multilink
no shutdown
interface Serial0/1/0
no ip address
encapsulation ppp
no keepalive
no fair-queue
ppp multilink
no shutdown
interface FastEthernet0/0
ip address 69.xxx.xxx.65 255.255.255.224
speed auto
full-duplex
no shutdown
speed auto
interface FastEthernet0/1
ip address 192.168.21.1 255.255.255.0
no shutdown
duplex auto
speed auto
For anything traveling though the FE0/1 interface, I want to use the below routes:
ip route 0.0.0.0 0.0.0.0 192.168.21.2 (Back to PIX, then gets filtered by Websense)
ip route 172.16.0.0 255.252.0.0 192.168.21.4
ip route 172.20.0.0 255.252.0.0 192.168.21.4
ip route 192.168.33.0 255.255.255.0 192.168.21.4
For anything traveling though the FE0/0 interface, I want to use the below routes:
ip route 0.0.0.0 0.0.0.0 67.XXX.XXX.125 (WAN Gateway back to ISP)
I would like to segragate the two interfaces, as if they were different routers.
Is this possible?
