catalyst 4506 switcing problems
harry
cat4506 connect to cat3750 but it doesnt work.i tried both str8 n cross cable but it doesnt work.
cat 4506 config
Building configuration...
Current configuration : 2356 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service compress-config
hostname lab_fke_utm_cat4506
enable secret xxxx
vtp domain ''
vtp mode transparent
ip subnet-zero
ip host cat4 10.1.1.4
ip dhcp snooping
spanning-tree mode pvst
power redundancy-mode redundant
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet2/1
interface GigabitEthernet2/2
interface GigabitEthernet2/3
interface GigabitEthernet2/4
interface GigabitEthernet2/5
interface GigabitEthernet2/6
interface FastEthernet3/1
switchport mode trunk
interface FastEthernet3/2
interface FastEthernet3/3
interface FastEthernet3/4
interface FastEthernet3/5
interface FastEthernet3/6
interface FastEthernet3/7
interface FastEthernet3/8
interface FastEthernet3/9
interface FastEthernet3/10
interface FastEthernet3/11
interface FastEthernet3/12
interface FastEthernet3/13
interface FastEthernet3/14
speed 100
duplex full
interface FastEthernet3/15
interface FastEthernet3/16
interface FastEthernet3/17
interface FastEthernet3/18
interface FastEthernet3/19
interface FastEthernet3/20
interface FastEthernet3/21
speed 10
interface FastEthernet3/22
interface FastEthernet3/23
switchport trunk allowed vlan 1
interface FastEthernet3/24
interface FastEthernet3/25
interface FastEthernet3/26
interface FastEthernet3/27
interface FastEthernet3/28
interface FastEthernet3/29
interface FastEthernet3/30
interface FastEthernet3/31
interface FastEthernet3/32
interface FastEthernet3/33
interface FastEthernet3/34
interface FastEthernet3/35
interface FastEthernet3/36
interface FastEthernet3/37
interface FastEthernet3/38
interface FastEthernet3/39
interface FastEthernet3/40
interface FastEthernet3/41
interface FastEthernet3/42
interface FastEthernet3/43
interface FastEthernet3/44
interface FastEthernet3/45
interface FastEthernet3/46
interface FastEthernet3/47
interface FastEthernet3/48
interface Vlan1
ip address 10.35.4.1 255.0.0.0
no ip http server
line con 0
stopbits 1
line vty 0 4
password cisco
login
end
pls help me ok
7 Replies 7
ankbhasi
Hi Harry,
Can you post the confgi od 3750 also. And please tell which port on 4k you are connected to which port 3750.
Ankur
cat4506 port fe3/1 cat 3750 fe1/0/2
config 3750
version 12.2
no service pad
hostname cat3750
enable secret xxx
no aaa new-model
switch 1 provision ws-c3750-48ts
ip subnet-zero
ip host cisco3700 10.35.1.1 255.0.0.0
ip host cat6506 10.35.6.1 255.0.0.0
ip host cat4506 10.35.4.1 255.0.0.0
ip host cat3750 10.35.3.1 255.0.0.0
ip host cat2950 10.35.2.1 255.0.0.0
no file verify auto
vlan internal allocation policy ascending
interface FastEthernet1/0/1
duplex full
speed 100
interface FastEthernet1/0/2
duplex full
speed 100
interface FastEthernet1/0/3
description ***connection to cat2950 int fa0/1***
duplex full
speed 100
interface FastEthernet1/0/4
duplex full
speed 100
interface FastEthernet1/0/5
duplex full
speed 100
interface FastEthernet1/0/6
duplex full
speed 100
interface FastEthernet1/0/7
duplex full
speed 100
interface FastEthernet1/0/8
duplex full
speed 100
interface FastEthernet1/0/9
duplex full
speed 100
interface FastEthernet1/0/10
duplex full
speed 100
interface FastEthernet1/0/11
duplex full
speed 100
interface FastEthernet1/0/12
duplex full
speed 100
interface FastEthernet1/0/13
duplex full
speed 100
interface FastEthernet1/0/14
duplex full
speed 100
interface FastEthernet1/0/15
duplex full
speed 100
interface FastEthernet1/0/16
duplex full
speed 100
interface FastEthernet1/0/17
duplex full
speed 100
interface FastEthernet1/0/18
duplex full
speed 100
interface FastEthernet1/0/19
duplex full
speed 100
interface FastEthernet1/0/20
duplex full
speed 100
interface FastEthernet1/0/21
duplex full
speed 100
interface FastEthernet1/0/22
duplex full
speed 100
interface FastEthernet1/0/23
duplex full
speed 100
interface FastEthernet1/0/24
duplex full
speed 100
interface FastEthernet1/0/25
duplex full
speed 100
interface FastEthernet1/0/26
duplex full
speed 100
interface FastEthernet1/0/27
duplex full
speed 100
interface FastEthernet1/0/28
duplex full
speed 100
interface FastEthernet1/0/29
duplex full
speed 100
interface FastEthernet1/0/30
duplex full
speed 100
interface FastEthernet1/0/31
switchport access vlan 2
duplex full
speed 100
interface FastEthernet1/0/32
duplex full
speed 100
interface FastEthernet1/0/33
speed 100
interface FastEthernet1/0/34
duplex full
speed 100
interface FastEthernet1/0/35
duplex full
speed 100
interface FastEthernet1/0/36
duplex full
speed 100
interface FastEthernet1/0/37
duplex full
speed 100
interface FastEthernet1/0/38
duplex full
speed 100
interface FastEthernet1/0/39
duplex full
speed 10
interface FastEthernet1/0/40
duplex full
speed 100
interface FastEthernet1/0/41
duplex full
speed 100
interface FastEthernet1/0/42
duplex full
speed 100
interface FastEthernet1/0/43
duplex full
speed 100
interface FastEthernet1/0/44
duplex full
speed 100
interface FastEthernet1/0/45
duplex full
speed 10
interface FastEthernet1/0/46
duplex full
speed 100
interface FastEthernet1/0/47
duplex full
speed 100
interface FastEthernet1/0/48
duplex full
speed 100
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface Vlan1
ip address 10.35.3.1 255.0.0.0
ip classless
ip http server
access-list 101 permit ip any any
control-plane
line con 0
password cisco
line vty 0 4
password cisco
login
line vty 5 15
no login
end
cat3750#
Hi friend,
The problem seems to be due to trunk negotiation.
Can you try hardcoding the port to trunk on the 3750 side
int fe 1/0/2
switchport trunk encap dot1q
HTH, rate if it does
Narayan
is it using str8 or cross cable?
Use a cross cable to connect between switches and let me know if it works out
Narayan
kamal-learn
Level 4
Level 4
hi
here ur using the dot1q as trunking protocol so first thing try to check if u have the same native vlan number in both switches,
the cat4506 is in transparent mode all its vlan information will not be transmitted to 3750.
do save the config of both switches and put the cat4506 in server or client mode,do remember u must have the same domain and the same password (case sensitive)..
if u put the cat4506 in server mode the risk of erasing all vlans on the 3750 is there.
on the 3750 configure the trunk port and if it does not work try to add
(switchport trunk nonegotiate/dynamic desirable...) see the diffrent possible working combination.
HTP
do rate if so
glen.grant
What doesn't work ? Do you get link lights between them when you hook them up or they just will not talk across the link . First line of business is to make sure you have link lights on both ends , you have to have that no matter what , that is the physical stuff , if yess then we can work from there .
