Routing
aconticisco
Level 2
Level 2
I have 2 1600 routers with one ethernet conn each. Cisco Router A is connected to a normal home router and Cisco router B is connected to a pc nic. Both cisco routers are connected to eachother with a serial back to back cable. I want that from the pc which is connected to Router B pass through router A and have an internet connection through my basic home router. Since router B lan interface is on a different subnet than the Lan home router interface I cannot ping it from Router B. can someone help thank you. All I can reach from router B is the Lan interface of Router A by using Eigrp
Assuming you can get to the Internet from routerA through your home router you can make routerB LAN access the Internet by configuring NAT on routerA.
The NAT configuration on routerA would something like this. Substitute the interface name and addresses according to your setup.
RouterA:
int e0/0
description connection to home router
ip nat outside
int e0/1
description connection to routerB
ip nat inside
ip nat inside source list 10 interface e0/0 overload
access-list 10 permit
Try this and let us know if it helped.
Sundar
these are my config
RouterA#show run
Building configuration...
Current configuration : 708 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname RouterA
boot system tftp newc1600z.123-6.bin 192.168.0.2
enable password xxx
ip subnet-zero
interface Ethernet0
description Connection to pc nic
ip address 192.168.1.33 255.255.255.224
no ip route-cache
no ip mroute-cache
interface Serial0
description Connection To Router B
ip address 192.168.0.100 255.255.255.0
router eigrp 20
network 192.168.0.0
network 192.168.1.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
no ip http server
line con 0
line vty 0 4
password xxx
login
end
RouterB#show run
Current configuration : 814 bytes
version 12.2
hostname RouterB
enable secret xxx.
enable password xxx
ip subnet-zero
ip name-server 192.168.1.66
interface Ethernet0
description Connection to Home Router
ip address 192.168.1.65 255.255.255.224
no ip mroute-cache
no cdp enable
interface Serial0
description Connection to Router A
ip address 192.168.0.101 255.255.255.0
no ip mroute-cache
clockrate 125000
router eigrp 20
network 192.168.0.0
network 192.168.1.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.66
no ip http server
line con 0
exec-timeout 0 0
line vty 0 4
password xxx
login
end
192.168.1.66 is my home router Lan ip address and the problem I want to fix is that from Router A I cannot ping 192.168.1.66 and therefore my pc which is connected to Router A cannot browse the internet.
How can I use NAT to fix the problem or is there a different way
Thank you for your time
What am I missing here. You say routerA is connected to home router and routerB is connected to PC. However, the configuration is showing exactly the opposite. Which is correct?
sorry the configuration is right
