routing
carl_townshend
Hi all, a quick question, If I have a router on a 10/8 address, would this be able to route say 10.99/16 to another location, or would it just try to route it out the interface with the 10/8 address assigned ?
7 Replies 7
Anand Narayana
Level 11
Level 11
Hi Carl,
Once you have a router, you can route to any network having any network class & there is no doubt on it.
Are you sure,As we have a router on a 10.0.0.0/8 address and we cant route to 10.99.0.0/16 from it ?
Hi Carl
Do u have any dynamic routing protocol configured between them. if so try disabling auto-sumarization on the routers and check.
Mahmood
no there is no dymanmic routing, its all done via static routes, can we do this ?
Hi carl,
configs on both ends would help.
can u paste the configs
Mahmood
keduncan
Level 2
Level 2
Your router will try to ARP for the 10.99.X.X out the interface with the 10.0.0.0/8 network assigned to it. If the router with the 10.99.X.X is connected to the 10.0.0.0/8 network and has ip proxy-arp enabled it should proxy the arp request and the packet will be sent out the interface. The router with the 10.99.X.X subnet will send the traffic.
EXAMPLE::
1Router---10.0.0.0--2Router 10.99.0.0
ip proxy-arp
Router 1 will ARP for 10.99.X.X..
router 2 (with IP proxy-arp enabled) will answer with it's arp address.
Router 1 will send the packet to router 2
ROuter 2 will forward the packet
1000BaseT
Community Member
I would use a route-map. Route maps are tricks that cause routers to forward packets to places they would not normally. HTH
