Routing
nycdcn123
Community Member
i'm setting up a lab, i want to be able to connect to it from public network. anybody has an idea how to do this ? i have a terminal server..
cisco_lad2004
Level 10
Level 10
1st thing u need is a public ip address. this will likely be assigned to ur ADSL router.
u then use terminal server ethernet to be on ur ADSL LAN.
then u need to get ur ADSL router to NAT or PAT so u can telnet to ur public IP and sepcific Port whicj will lead u to terminal server ethernet
Sam
nycdcn123
Community Member
thank you for that answer, do you know what type of ADSL router i should get. i intend to use the same public IP my service provider assigned to me. it has never changed. lets assumed it changes how do u know..thank you so much in advance..
most DSL router have these functionalities today.
Try Linksys websites, Zyxel etc..
there are few sites that can tell u what is ur public address.
such as http://www.whatsmyipaddress.com/
good luck !
Sam
thank you so much Sam.
