RP drops / Input drops on 6500 Sup 720 10GE
torstefan
Dear Community,
What does RP drops entail?
We are experiencing 0.23 % drops on an vlan int on one of our 6500. This interface is an L3 to a server-subnet.
29563976÷12851487771×100 = 0.230043218
Doing a sh int vlan 238 switching shows 30935411 RP (Route Processing) drops.
It was a bit unclear to me in the thread "Input queue drops on 6500 vlan interface" if RP drops was through the router, or to the router(mgmnt)?
I can do a netdr to see what traffic goes to it. It should not generate CPU load, but I thnk I will wait untill afterhours before I try that commnad.
- do NETDR:
-- debug netdr cap rx vlan 238
-- show netdr cap
Any repies are met with gratitude.
Cheers,
Tor Stefan
Reference
Input queue drops on 6500 vlan interface - https://supportforums.cisco.com/thread/2119895
Troubleshoot Input Queue Drops - http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml#topic3
Show commands
xxx-k05-rs6#sh int vlan 238
Vlan238 is up, line protocol is up
  Hardware is EtherSVI, address is 0023.040d.d1c0 (bia 0023.040d.d1c0)
  Description: xxx.238.0_24 sak:P1381
  Internet address is 161.4.238.1/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 46/255, rxload 159/255
  Keepalive not supported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 2d22h
  Input queue: 0/75/29563976/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 898836000 bits/sec, 106595 packets/sec
  5 minute output rate 183224000 bits/sec, 59158 packets/sec
  L2 Switched: ucast: 3298256993 pkt, 1408022251821 bytes - mcast: 3460431 pkt, 476653445 bytes
  L3 in Switched: ucast: 12851487771 pkt, 15530704413500 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 7375928081 pkt, 2467778470794 bytes mcast: 0 pkt, 0 bytes
     16127281689 packets input, 17567277881823 bytes, 0 no buffer
     Received 5080351 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 34740 throttles
     7536851172 packets output, 2576927516962 bytes, 0 underruns
     0 output errors, 0 interface resets
-k05-rs6#sh int vlan 238 switching
Vlan238 servernett_161.4.238.0_24 sak:P1381
          Throttle count      36171
        Drops         RP   30935411         SP          0
  SPD Flushes       Fast          0        SSE          0
  SPD Aggress       Fast          0
SPD Priority     Inputs          0      Drops          0
     Protocol       Path    Pkts In   Chars In   Pkts Out  Chars Out
        Other    Process  380704913 34246329102          0          0
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
           IP    Process 1346950495 340903528931  160716715 18960732601
            Cache misses          0
                    Fast   22225740 2814363123   87068544 28190395977
               Auton/SSE 3319146968178 3623406840541663 1780517499010 852526331293699
      DEC MOP    Process          0          0     169820   21906780
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
          ARP    Process 1050722763 63043389126  119702916 13406726592
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Hi Tor Stefan,
it seems indeed host with IP 161.4.238.134 and MAC 00.26.55.7F.66.C0 with is sending lots of ARP requests for all (or lots of) hosts in vlan 238. In the Target Protocl Address we can see lots of hosts (A104EEDE  A104EEE5 etc).
Not sure if this is a malfunctioning, for sure it is the root cause.
You need to check what that server is doing... as a start check its arp table and see why it keeps sending those requests.
Meanwhile you could enlarge the input queue from the default 75 packets to something bigger (2000 for instance) or also you could configure the arp policer  (sup720 feature) if things get worse.
Riccardo
5 Replies 5
rsimoni
The counter indicates what is being dropped at RP level and does not diffirentiate from traffic going TO or THROUGH the router. In ideal conditions no transit traffic is supposed to go to the RP in order to be forwarded as it should be handled at hardware level by the PFC or DFC if present. So in this condition all the input drops happen for traffic destined TO the RP iteself (management traffic, protocols etc.). However in your outputs we can already see that IP process is forwarding some traffic. This should not happen as MLS CEF forwarding should occur instead (hardware level as I wrote above).
It would seem that traffic entering in vlan 238 (part of it at least) is sent to the RP to be forwarded by IP Process (not even in software CEF). NETDR will tell you exactly what is being 'punted' (this is the name of this operation).
Go for it, it is extremely safe as it will not add any load to the CPU as it is just a circular buffer.
Also, go and check the CPU utilization as you will likely see some interrupts utilization.
sh proc cpu sorted | e 0.00
It would also be interesting checking the following:
sh tcam int vlan 238 acl in ip det
and
sh mls cef exception status
Post these outputs (including netdr) for us to check.
Riccardo
It seems to me that 00.26.55.7F.66.C0, which is a server I have now located, is generating loads of ARP (protocol 0806)
broadcasts.
Its a server which runs HP Insight Manager..
Could it be a mailfunc. nic?
But, here follows the different commands.
-k05-rs6#sh proc cpu sorted | e 0.00
CPU utilization for five seconds: 9%/3%; one minute: 8%; five minutes: 8%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  12   5063354361128506211        448  1.59%  0.88%  0.81%   0 ARP Input
538   5871670563215955670          0  1.51%  0.53%  0.52%   0 Port manager per
321   6192236963704860394          0  0.87%  0.43%  0.44%   0 IP Input
  52    75552492   2614437      28898  0.79%  0.09%  0.06%   0 Per-minute Jobs
415    51906936 169324853        306  0.23%  0.06%  0.05%   0 CEF: IPv4 proces
250   262014368 847263604        309  0.23%  0.20%  0.19%   0 DHCPD Receive
358    55731092  59900016        930  0.15%  0.07%  0.06%   0 QOS Stats Gather
388    81079936  92758699        874  0.07%  0.09%  0.09%   0 IPC LC Message H
594   8327071482834682139          0  0.07%  0.21%  0.19%   0 SNMP ENGINE
315    31229984 350667956         89  0.07%  0.03%  0.01%   0 CDP Protocol
  84    36948940  80829033        457  0.07%  0.05%  0.05%   0 ARP HA
-k05-rs6#sh mls cef exception status
Current IPv4 FIB exception state = FALSE
Current IPv6 FIB exception state = FALSE
Current MPLS FIB exception state = FALSE
-k05-rs6#sh tcam int vlan 238 acl in ip det
* Global Defaults shared
DPort - Destination Port   SPort - Source Port        TCP-F - U -URG             Pro   - Protocol
I     - Inverted LOU       TOS   - TOS Value                - A -ACK             rtr   - Router
MRFM  - M -MPLS Packet     TN    - T -Tcp Control           - P -PSH             COD   - C -Bank Care Flag
      - R -Recirc. Flag          - N -Non-cachable          - R -RST                   - I -OrdIndep. Flag
      - F -Fragment Flag   CAP   - Capture Flag             - S -SYN                   - D -Dynamic Flag
      - M -More Fragments  F-P   - FlowMask-Prior.          - F -FIN             T     - V(Value)/M(Mask)/R(Result)
X     - XTAG               (*)   - Bank Priority
Interface: 238   label: 1   lookup_type: 0
protocol: IP   packet-type: 0
|T|Index|  Dest Ip Addr | Source Ip Addr|     DPort     |     SPort     | TCP-F |Pro|MRFM|X|TOS|TN|COD|F-P|
Entries from Bank 0
V 18396         0.0.0.0         0.0.0.0       P=0             P=0        ------   0 ---- 0   0 -- --- 0-0
M 18404         0.0.0.0         0.0.0.0         0               0        ------   0 ---- 0   0
R rslt: L3_DENY_RESULT                rtr_rslt: L3_DENY_RESULT                      hit_cnt=0
Entries from Bank 1
V 36259         0.0.0.0         0.0.0.0       P=0             P=0        ------   0 ---- 0   0 -- C-- 0-0  <-
M 36260         0.0.0.0         0.0.0.0         0               0        ------   0 ---- 0   0             <-
R rslt: PERMIT_RESULT (*)             rtr_rslt: PERMIT_RESULT (*)                   hit_cnt=292182389  <-
V 36828         0.0.0.0         0.0.0.0       P=0             P=0        ------   0 ---- 0   0 -- --- 0-0
M 36836         0.0.0.0         0.0.0.0         0               0        ------   0 ---- 0   0
R rslt: L3_DENY_RESULT (*)            rtr_rslt: L3_DENY_RESULT (*)                  hit_cnt=17
------- dump of incoming inband packet -------
interface Vl238, routine mistral_process_rx_packet_inlin, timestamp 00:03:47
dbus info: src_vlan 0xEE(238), src_indx 0xB5A(2906), len 0x40(64)
  bpdu 0, index_dir 0, flood 1, dont_lrn 0, dest_indx 0x40EE(16622)
  E0820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE4319
mistral hdr: req_token 0x0(0), src_index 0xB5A(2906), rx_offset 0x76(118)
  requeue 0, obl_pkt 0, vlan 0xEE(238)
destmac FF.FF.FF.FF.FF.FF, srcmac 00.26.55.7F.66.C0, protocol 0806
layer 3 data: 00010800 06040001 0026557F 66C0A104 EE860000 00000000
              A104EE9A 00000000 00000000 00000000 00000000 00000000
              00000000 00000000 0000FFFF
  E8820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE7B19
              A104EE99 00000000 00000000 00000000 00000000 00000000
  F0820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE3319
              A104EE92 00000000 00000000 00000000 00000000 00000000
  F8820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE0B19
              A104EE96 00000000 00000000 00000000 00000000 00000000
  00820400 00EE0000 0B5A0000 40080000 E0000040 0E000008 00000018 40EE0343
destmac FF.FF.FF.FF.FF.FF, srcmac 00.26.55.7F.98.C8, protocol 0806
layer 3 data: 00010800 06040001 0026557F 98C8A104 EE920000 00000000
              A104EE86 00000000 00000000 00000000 00000000 00000000
  08820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE5B16
              A104EE98 00000000 00000000 00000000 00000000 00000000
  10820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE1316
              A104EE8B 00000000 00000000 00000000 00000000 00000000
  18820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE2B16
              A104EE97 00000000 00000000 00000000 00000000 00000000
  20820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE8316
              A104EE94 00000000 00000000 00000000 00000000 00000000
  28820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EEBB16
              A104EE8C 00000000 00000000 00000000 00000000 00000000
  30820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EEF316
              A104EE79 00000000 00000000 00000000 00000000 00000000
  38820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EECB16
              A104EE93 00000000 00000000 00000000 00000000 00000000
  48820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE1B13
              A104EE90 00000000 00000000 00000000 00000000 00000000
  50820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE5313
              A104EE91 00000000 00000000 00000000 00000000 00000000
  58820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE6B13
              A104EE8E 00000000 00000000 00000000 00000000 00000000
dbus info: src_vlan 0xEE(238), src_indx 0xB5C(2908), len 0x40(64)
  68820400 00EE0000 0B5C0000 40080000 E0000550 0E000008 00000008 40EEB9E5
mistral hdr: req_token 0x0(0), src_index 0xB5C(2908), rx_offset 0x76(118)
destmac FF.FF.FF.FF.FF.FF, srcmac 00.22.19.8F.36.0D, protocol 0806
layer 3 data: 00010800 06040001 0022198F 360DA104 EE8E0000 00000000
  70820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EEB313
              A104EE89 00000000 00000000 00000000 00000000 00000000
  78820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE8B13
              A104EE63 00000000 00000000 00000000 00000000 00000000
  90820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE931C
              A104EEEB 00000000 00000000 00000000 00000000 00000000
  98820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EEAB1C
              A104EEE8 00000000 00000000 00000000 00000000 00000000
  A0820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE031C
              A104EEE9 00000000 00000000 00000000 00000000 00000000
  A8820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE3B1C
              A104EEE7 00000000 00000000 00000000 00000000 00000000
  B0820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE731C
              A104EEE0 00000000 00000000 00000000 00000000 00000000
  B8820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EE4B1C
              A104EEDE 00000000 00000000 00000000 00000000 00000000
  D8820400 00EE0000 0B5A0100 40080000 E0000520 02000008 00000008 40EEEB19
              A104EEE5 00000000 00000000 00000000 00000000 00000000
Hi Tor Stefan,
Riccardo
Thank you for your answer. I also liked the little brainteaser. I had to find out where you got the host IP from. I don't work that much (yet) with hex, but I do have an advanced calculator in my Linux
indeed you can get lots of interesting info by exploring the captured data comparing it with an ARP frame
http://ipv6.com/articles/general/Address-Resolution-Protocol.htm
you see the protocol (IP), the type of ARP (request), the sender, the target etc,
