sending ping to a device and receiving 2 replies
carl_townshend
Hello all
I have a funny situation, I send a ping reply to a server and get 2 responses back, I also get source quench messages from the server.
Any ideas what this could be ?
cheers
mlund
Level 7
Level 7
Hi Carl
Source-quench means that the server, when answering the ping, indicates that it is busy.
That's probably why the server is not replying on every ping.
info on this link
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6057.shtml
/Mikael
rsimoni
Hi Carl,
If the device which sends 2 replies is always the same one and it always sends a standard reply and a source quench reply it might be a normal behavior for that device when it is busy. You might want to check why it is busy.  In any case I guess this is something you should check with the server vendor to see how the tcp/ip stack has been implemented to see if this is the expected behavior.
I would not be too worried anyway.
Riccardo
