RPS 2300 IP allocation
janesh_abey
Could someone tell me how to configure an IPaddress for a PWR-RPS 2300 please?.I tried finding info on the website but no luck as yet. RPS 2300 will be used on stack of 3750E series switches.
i think ihave read somewhere there is no IP adress to assign :
if you use RPS2300 behind a 3750, you will have access on it but no configuration if used with another switch.
Extract :
"Management
Q. Does the Cisco RPS 2300 offer enhanced management features when connected to Cisco switches?
A. Yes. The Cisco RPS 2300 offers enhanced management capabilities when attached to Cisco Catalyst 3750-E and 3560-E Series Switches."
From : http://www.cisco.com/en/US/products/ps7148/products_qanda_item0900aecd805bbf21.shtml
Bye
GB.
myanuary
guillaume is right, there is no ip address assigning...
after you connect to switch, you can configure it by command "power rps ?" on priviledge-edge mode on that switch..
Switch#power rps ?
thanks for ur answer.
