RPS Stand-by mode
taimoor khan
Hello GUys,
I am receiving these error on our stack-switches;
Apr 23 08:35:42.586 MDT: %PLATFORM_ENV-3-RPS_CHANGE_TO_STANDBY: RPS state changed to standby
Apr 23 08:35:51.687 MDT: %PLATFORM_ENV-3-RPS_CHANGE_TO_STANDBY: RPS state changed to standby
Apr 23 08:35:54.757 MDT: %PLATFORM_ENV-3-RPS_CHANGE_TO_STANDBY: RPS state changed to standby
Apr 23 08:36:00.830 MDT: %PLATFORM_ENV-3-RPS_CHANGE_TO_STANDBY: RPS state changed to standby
Apr 23 08:36:03.900 MDT: %PLATFORM_ENV-3-RPS_CHANGE_TO_STANDBY: RPS state changed to standby
Apr 23 08:36:09.973 MDT: %PLATFORM_ENV-3-RPS_CHANGE_TO_STANDBY: RPS state changed to standby
Apr 23 08:36:13.035 MDT: %PLATFORM_ENV-3-RPS_CHANGE_TO_STANDBY: RPS state changed to standby
Apr 23 08:36:31.112 MDT: %PLATFORM_ENV-3-RPS_CHANGE_TO_STANDBY: RPS state changed to standby
Our management wants us to stop these errors, could any one tell how do I stop it ?
Here is the more output results
#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 45 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 49 Degree Celsius
Red Threshold    : 59 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  C3K-PWR-265WAC      QCS1408C0KH  OK              Good     N/A      265/0
2  C3K-PWR-265WAC      QCS1409C06L  OK              Good     N/A      265/0
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Standby         CiscoRPS          FDO1415SG7A  4
2   Standby         CiscoRPS          FDO1415SG7A  1
RPS Name: CiscoRPS
  State: Standby
  PID: PWR-RPS2300
  Serial#: FDO1415SG7A
  Fan: Good
  Temperature: Green
  RPS Power Supply A: Present
    PID             : C3K-PWR-1150WAC
    Serial#         : ART1536W055
    System Power    : Good
    PoE Power       : Good
    Watts           : 300/800 (System/PoE)
  RPS Power Supply B: Present
    Serial#         : ART1536W05D
    System Power    : Good
    PoE Power       : Good
DCOut  State   Connected  Priority  BackingUp  WillBackup  Portname        SW#
    1  Active  Yes               6  No         Yes         sw8              2
    2  Active  Yes               6  Yes        Yes         <>                -
    3  Active  Yes               6  Yes        Yes         <>                -
    4  Active  Yes               6  No         Yes         sw8              1
    5  Active  Yes               6  Yes        Yes         <>                -
    6  Active  Yes               6  Yes        Yes         <>                -
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(44r)SE3, RELEASE SOFTWARE (fc3)
Version ID                      : V03
Switch Ports Model              SW Version            SW Image
Version ID                      : V03
InayathUlla Sharieff
Hi Taimoor,
Might be 2 issues here.
1 - Switch reloaded
2 - After the reload, RPS complaining with the following errors in logs:
Have a look at the following URL,  specifically Table 4-1  and check the
standby/Active LED on the RPS
http://www.cisco.com/en/US/docs/switches/power_supplies/rps2300/hardware
/installation/guide/rpstrb.html#wpxref72657
Standby/Active LED is blinking amber.  >>>>> The RPS 2300 is in standby
mode. >>>>>Press the Standby/Active button to put the RPS 2300 in active
mode.
Verify the LED on the RPS and if the above is all you need to do.
If not, have a look at Table 4 - 1 for additional diagnostics you can do
on RPS.
To reset the RPS if needed:
/installation/guide/rpsoview.html#wp1054006
"To manually reset the ports to the default settings, press both the
Select and Standby/Active buttons for 3 seconds, and then release. All
system and port LEDs flash green, then amber before the RPS 2300 begins
operating with the default port priority settings."
But do verify or let me know if the LED was blinking amber or so.  If
that is the case, just pressing the Standby/Active button should make
the led go green.
Inayath
*Plz rate the usefull post .
Hello Anayat,
Thanks for the reply thats very useful information. I have a question so if I change RPS into active-mood using router config than it wont effect the running router/production server ? I belive the guy who install these stacks forget to turn Active the rps.
Hi Taimoor,
Typically you should not. But still it would be worth if you could do off business hours.
Inayath
Please rate and mark the post as answered so others can benefit from it.
