12-02-2024 07:27 AM
I have a pair of C9500-48Y4C in stackwyse virtual mode.
I need to use SFP-10/25G-CSR-S as sfp for the 2 SVL. The links don't goes UP as it seem i need to enable RS-FEC.
(With 10G-SR it's ok )
My problem is that i don't have the command on SVL ports (Eg twentyFiveGigE 1/0/47)
CR-9500#show run int twentyFiveGigE 1/0/47
Building configuration...
Current configuration : 64 bytes
interface TwentyFiveGigE1/0/47
stackwise-virtual link 1
end
CR-9500#
CR-9500(config-if)#?
Distributed stack interface configuration commands:
default Set a command to its defaults
description Interface specific description
exit Exit from interface configuration mode
no Negate a command or set its defaults
stackwise-virtual Configure Stackwise Virtual link values
CR-9500(config-if)#
Is there any solution ?
The version is:
Cisco IOS XE Software, Version 17.12.04
Cisco IOS Software [Dublin], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.12.4, RELEASE SOFTWARE (fc3)
Best regards
12-02-2024 07:50 AM
I dont think it issue of FEC other than it issue of SVL restrictions in platform.
Not all port accpet to be use for SVL.
So check stackwise virtual for your SW platform and check port restrictions
MHM
12-02-2024 11:14 AM
Thanks for your reply.
The ports used for SVL are ok for SVL. When i use 10G-SR sfp on same ports,all is OK, (SVL UP, redundancy fully functionnal, ports channels to access switchs UP, etc...).
The RS-FEC is noticed in 25G datasheet. On non svl links i have the commands, but not on SVL interfaces.
12-04-2024 10:50 AM
it not sense cisco use 25G for SVL and to make it UP you need command not available under SVL
contact cisco about this point
MHM
