RSPAN Problems
MattSherman5680
Visitor
I have a simple RSPAN setup between two 3560 switches.  All ports are in VLAN 1.  When I try to monitor VLAN 1 as a source I lose all connectivity to the remote switch as soon as I enable the RSPAN.  If I use physical ports as the source traffic the connectivity stays up but the only traffic I see on the remote capture port is broadcast and multicast.  Any ideas on what I'm doing wrong?
Source Switch
vlan 902
remote-span
monitor session 1 source interface Gi0/43
monitor session 1 destination remote vlan 902
#show monitor
Session 1
Type : Remote Source Session
Source Ports :
Both : Gi0/43
Dest RSPAN VLAN : 902
#sh int trunk
Port Mode Encapsulation Status Native vlan
Gi0/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/1 1-4094
Port Vlans allowed and active in management domain
Gi0/1 1-3,5-9,90,100,902
Port Vlans in spanning tree forwarding state and not pruned
Destination Switch
vlan 902
remote-span
monitor session 1 destination interface Gi0/6
monitor session 1 source remote vlan 902
#show monitor
Session 1
Type : Remote Destination Session
Source RSPAN VLAN : 902
Destination Ports : Gi0/6
Encapsulation : Native
Ingress : Disabled
#show int trunk
Gi0/1 1-4094
Gi0/1 1-3,902
Gi0/1 1-3,902
9 Replies 9
balaji.bandi
Do you have network topology how these Switches connected ? like Source Switch and Designation SPAN port.
BB
Yes, see attached.  I changed the VLAN from 1 to 2 on the assumption that it might be a native VLAN thing but didn't make a difference.
just checking is this a real world setup or any simulation lab ?
BB
It's real
Hello
Once a destination port is a part of a span session it doesn't work as a normal switchport port anymore , so try defaulting interface gig0/6 on sw2, then test again.
Kind Regards
Paul
I tried it and it didn't make a difference.
Matt
Hello
Can you also try specifying the ingress vlan
Sw2
monitor session 1 destination interface Gi0/6 ingress vlan 2
Kind Regards
Paul
I believe that the ingress setting just allows the capture host on that port to actually use the port for access at the same time.  I have tried that and still the same problem - only seeing broadcast/multicast as shown below:
Hello MattSherman5680,
Is the capturing device capable of capturing traffic in promiscuous mode?
