03-03-2013 09:02 AM - edited 03-07-2019 12:01 PM
Recently implemented a branch office LAN with dual core switches (core a and core b) all access switches connect to core a and core b.
core a is root bridge with priority 0, b is as secondary root bridge with priority 4096 and rest of the switches with defaulf priority.
when a access switch is connected to core a and core b. RSTP converged but core b elected as Alternate role instead as designated on access switch side to core a as root port and core b as designated.
Core B
Interface Role Sts Cost Prio.Nbr Type
Gi1/1/1 Altn BLK 20000 128.49 P2p
Core A
Te1/1/1 Desg FWD 2000 128.53 P2p
Access Switch
Te1/1/1 Root FWD 2000 128.53 P2p
Gi2/0/1 Desg FWD 20000 128.55 P2p
core02
Port 49 (GigabitEthernet1/1/1) of VLAN0001 is alternate blocking
Port path cost 20000, Port priority 128, Port Identifier 128.49.
Designated root has priority 1, address e02f.6d46.8880
Designated bridge has priority 32769, address acf2.c5b2.3380
Designated port id is 128.55, designated path cost 2000
Timers: message age 15, forward delay 0, hold 0
Number of transitions to forwarding state: 0
Link type is point-to-point by default
Loop guard is enabled on the port
BPDU: sent 4, received 2417
sera
Port 53 (TenGigabitEthernet1/1/1) of VLAN0001 is root forwarding
Port path cost 2000, Port priority 128, Port Identifier 128.53.
Designated bridge has priority 1, address e02f.6d46.8880
Designated port id is 128.53, designated path cost 0
Timers: message age 16, forward delay 0, hold 0
Number of transitions to forwarding state: 2
BPDU: sent 21, received 2837
sera
Port 55 (GigabitEthernet2/0/1) of VLAN0001 is designated forwarding
Port path cost 20000, Port priority 128, Port Identifier 128.55.
Timers: message age 0, forward delay 0, hold 0
Number of transitions to forwarding state: 1
BPDU: sent 2665, received 4
core01
Port 53 (TenGigabitEthernet1/1/1) of VLAN0001 is designated forwarding
Loop guard is enabled by default on the port
BPDU: sent 5566, received 26
How can I influence access switch port Gi2/0/1 to be elect as Alternate port and Core B port G1/1/1 as Designated port..?
Thanks in advance
03-03-2013 09:29 AM
Greetings. This question is a bit confusing because you refer to coreA and CoreB but then in your STP output we have core01 and core02. I assume core01 is coreA and core02 is coreB...
Anyway, it might be helpful if you included the output of:
show run | include spanning
on both core switches, as well as the output of
show spanning-tree
on both core switches, but just include the top sections (Root ID and Bridge ID information).
Also indicate in your drawing which ports are connecting the switches together.
Matt
03-03-2013 09:45 AM
Hello Matt and santosh,
While some additional information may be useful, please note that a designated port is elected as a port that sends the best BDPUs on the segment. BPDUs are compared in this sequence of fields:
If we can trust santosh that the core switches have priorities of 0 and 4096, respectively, it follows then that the CoreB switch's Root Path Cost must be higher than the Root Path Cost of the access switch. Simply put, the access switch appears to be on a faster link towards the CoreA than the CoreB.
Best regards,
Peter
03-03-2013 01:04 PM
Hi Matt, please consider switch names as corea and coreb, Thank you
coreb# sh run | in spann
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree portfast bpduguard default
spanning-tree pathcost method long
spanning-tree vlan 1-4094 priority 4096
coreb#sh spann
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 1
Address e02f.6d46.8880
Cost 10000
Port 488 (Port-channel1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 4097 (priority 4096 sys-id-ext 1)
Address e02f.6d2f.8380
Aging Time 300 sec
__________________________________________________________________________
core a# sh run | in spann
spanning-tree vlan 1-4094 priority 0
corea#sh spann
VLAN0001
Root ID Priority 1
This bridge is the root
Bridge ID Priority 1 (priority 0 sys-id-ext 1)
Aging Time 300 sec
Diagram with interface details
03-03-2013 02:04 PM
If I am interpreting your output correctly, the distance of your CoreB to CoreA (root) is 10000 while the distance of the Access switch to CoreA is 2000. That would explain why CoreB blocks its port towards the Access switch.
The solution should be fairly easy here - on CoreB Port-channel1 interface (the current root port), use the spanning-tree cost 1 command or any other value that is less than 2000.
Best regards,
Peter
03-05-2013 06:21 AM
Hi Peter, It worked very fine, but same is not getting effect for other 2 more access switches connected to coreA and coreB switches.
They are also connected like same tengig to coreA and gig to CoreB with same configured as access switch 1.
Thanks for your support
03-08-2013 01:41 PM
Hello Santhosh,
Please post the entire show span vlan 1 output from core-a, core-b and the two access switches that you need to tweak. Thanks!
Best regards,
Peter
