RTP Priority catalyst 3560
mvaldez83
Community Member
Does the Catalyst 3560 support the RTP priorty command? We are implementing a voice recording solution on the network and it requires RTP to be enabled.
WS-C3560-48PS
Version ID:V05
Software:
12.2(35)SE5 (IPBASE)
When i log into my switch I will go IP ? and dont see RTP as a choice. it's my understanding the basic command is ip rtp priority
THanks,
Matt
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Don't believe this command is supported on the 3560, which has a less flexible QoS support than software based routers that support IP RTP priority.  However, you can likely meet your voice solution needs within the capabilities of a 3560's QoS features.
