Ruggedized SFPs in 3850's
mcollier
All, I hope you can help.  We have several WS-C3850-24S-E's in our network.  I am trying to figure out whether we can use ruggedized SFP modules in them, such as the GLC-LX-SM-RGD.  In the SFP compatibility matrix, it doesn't list the RGD modules as compatible.  Is this really the case that they can't be used?  I find it hard to believe that they won't work.  Thanks.
acampbell
Hi.
I do not think your switch supports these SFPs
GLC-LX-SM-RGD
The compatability matrix was updated on 30th Oct
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
Still not mentioned in the 3850 section
Regards, Alex. Please rate useful posts.
dperezoquendo
You can try the following commands though it may not always work for third party SFPs:
service unsupported-transceiver
no errdisable detect cause gbic-invalid
