Rule based span on Nexus 7000
Joris Deprouw
Hi all,
I'm trying to configure rule based span on my Nexus 7000.
I want to monitor some vlans, but limit the traffic going to my monitor station by using frame-type ipv4 filter.
The link below explains how to configure it, but my nexus doesn't recognise the command "mode extended".
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/system_management/configuration/guide/sm_nx_os_cg/sm_14span.html#wp1286697
Am I missing something? I'm running version 6.1.3.
Joris
NEXUS(config)# monitor session 1
NEXUS(config-monitor)# mode extended
% Invalid command at '^' marker.
NEXUS(config-monitor)# mode ?
*** No matching command found in current mode, matching in (exec) mode ***
  connect  Notify system on modem connection
  restart  Reenabling modem port
Steve Fuller
Level 9
Level 9
Hi Joris,
The rule based SPAN filtering was not introduced until NX-OS 6.2 so will not be available to you with NX-OS 6.1(3).
See the section SPAN in the NX-OS 6.2 release notes.
Steve Fuller
Level 9
Level 9
Hi Joris,
Joris Deprouw
Thanks Steve
