Run a bash script on Cat9k or switches
CiscoBrownBelt
Level 6
Level 6
Can you run a Linux bash script on a Cat9k or any newer switch in general? After uploading it I guess to dir, how would you execute it? Basically where is best place to upload it then I guess go into linux shell to execute it?
Mark Elsen
 - You can do it on nexus (not on catalyst) : https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/programmability/guide/b_Cisco_Nexus_9000_Series_NX-OS_Programmability_Guide_7x/Bash.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Looks like the guestshell enable command is supported as I was also able to turn IOx feature on.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/prog/configuration/166/b_166_programmability_cg/guest_shell.html
I entered it but got
SW1#guestshell enable
Interface will be selected if configured in app-hosting
Please wait for completion
% Error: No interface configuration for guestshell
Leo Laohoo
Use EEM but nevert use KRON.
Embedded Event Manager to upload and run a script? I'm sorry not sure I am tracking what you mean.
