Running copy running-config tftp with least privilage
giridar
Hi All,
 I am planning to backup device configuration using ManageEngine OpManager, it has a tftp server and we can add the devices, so it requires a credentials
the user account should be able to run copy running-config tftp, as I checked this command is only available for privilege 15
i don't want to use a privilage 15 user account for this to avoid any risks, since it has permission to modify the device configurations
is there any way to assign copy running-config tftp to a least privilege level
enable secret is already configured so i can't reduce the level of it and assign the exce
thanks in advance
balaji.bandi
Try below and let us know how it goes :
#username backupuser privilege 7 password 7 backupuserpassword
#privilege exec level 7 copy running-config
BB
6 Replies 6
balaji.bandi
BB
thank you very much, will this copy all the configurations or only the ones that this level have access
balaji.bandi
The backupuser with Priv 7 - backupuser have access to that command only. - its like Role based access.
BB
thank you,
seems like the application I am using is taking the backup using show running-config and show startup-config
so I added these
privilege exec level 7 terminal length 0
privilege exec level 7 show running-config
privilege exec level 7 show startup-config
so it needs an account that has access to all the cinfigurations
is it possible to give full access except for configuration terminal
balaji.bandi
You can also do less priv level -
Since you do not provide the device information or IOS  - high level you can do as below
username bbandi privilege 5 secret 5 YYYYYYYYYYYYYYYYYYY
privilege exec level 5 show running-config view full
BB
