04-11-2012 05:44 AM - edited 03-07-2019 06:04 AM
Does anyone know if this will work, is supported on a 2960 running c2960-lanlitek9-mz.12.2.50.SE5?
Customer has tried to implement this & looses connectivity as soon as config applied
cheers
Colin
04-14-2012 08:18 AM
Hi Colin,
It would be very helpful if you could post the entire MST configuration from both switches so that we can have an idea what we are dealing here with. Also, any logging messages displayed during the network outage from any of these switches are necessary to narrow down the possible cause of the problem.
A couple of hints:
Looking forward to reading from you.
Best regards,
Peter
04-26-2012 07:46 AM
Peter,
I went to the customer site to test the scenario...
HP Core 1 -------- HP Core 2
Cisco 2950---------Cisco 2960
We got this error message when connecting the second link.
%SPANTREE-2-PVSTSIM_FAIL: Blocking designated port Fa0/1: Inconsitent superior PVST BPDU received on VLAN 899, claiming root 0:0024.a83c.8600
config on 2960
spanning-tree mode mst
spanning-tree mst configuration
instance 0 vlan 1 - 4094
name GNET
revision 1
no spanning-tree optimize bpdu transmission
name GNET
revision 1
int g0/1
spanning-tree mst pre-standard
interface connecting to 2950
int g0/1
config on 2950
name GNET
revision 1
any idea's
04-26-2012 04:28 PM
Colin,
So far, I can tell that the 2950 is - for some so far unknown reason - receiving PVST+ BPDUs on its Fa0/1 port, and this BPDU fails to meet special criteria that allows the MSTP and PVST+ to seamlessly interoperate. That is why the port declares the PVST Simulation Inconsistency.
If the entire network was properly configured for MST, there should be no PVST+ BPDUs present at all. I am therefore wondering where do these PVST+ BPDUs come from. Are both HP switches properly configured to run MSTP? Are there any other Catalyst switches in this network that are still running PVST+? Where should the STP root be placed?
Providing me with the requested output of the commands I specified in my first response would be a good starting point. Without knowing more about your topology and the configuration of its elements, it is hard to tell anythng else.
Best regards,
Peter
04-27-2012 01:21 AM
Peter,
The problem is that i am not on the custoers site.
They have the core HP switches running MSTP & the edge switches (2960/50's) running PVST & the request is to migrate all to MSTP.
However, the issue seen above was when we converted a 2950 & a 2960 to MSTP.
The connectivity is all over the place, with switches daisy chained to one another.
Is there a way of stopping the port from blocking when this BPDU is seen, as they have around 75 switches to migrate & we don't really want to have to connect via the console to each device, if possible.
Colin
05-01-2012 02:31 PM
Hello Colin,
I apologize for answering lately.
Ah, I see. The issue you are seeing is caused by Cisco's own mechanism of cooperation between MSTP and PVST+, and the HP switches are not contributing in any way to the problems you are experiencing.
In short and without going into much detail, in order for a Cisco running MSTP to properly interact with PVST+ region without causing network outages, two configuration options must be met:
Only if one of these requirements is met, the cooperation of MSTP and PVST+ region will not lead to permanently blocked ports. Before gradually migrating to MSTP, you have to decide which scenario you want to implement and make necessary precautions before actually starting to modify the STP mode.
Best regards,
Peter
