RX Power low warning ? Is this a big problem
joshhboss
Hi Everyone, I have 2 switches connected together through a port channel, and i am getting this error in the logs..
SiteOpsOfficeSw204(config-if-range)#
Jan 12 08:03:30.861 EST: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/0/50: Rx power low warning; Operating value: -22.9 dBm, Threshold value: -19.0 dBm.
SiteOpsOfficeSw204(config-if-range)#do sh int gig1/0/50
GigabitEthernet1/0/50 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is c8f9.f99a.a6b2 (bia c8f9.f99a.a6b2)
  Description: PortChanneltoMain
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:10, output 00:00:10, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1273000 bits/sec, 127 packets/sec
  5 minute output rate 3000 bits/sec, 4 packets/sec
     521914 packets input, 486394285 bytes, 0 no buffer
     Received 79774 broadcasts (77395 multicasts)
     0 watchdog, 77395 multicast, 0 pause input
     251717 packets output, 28389735 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
I have read that this could be a cosmetic error, but i also showed the show interface to see if someone could help me understand if there is anything i should do to resolved this.
balaji.bandi
1000BaseLX SFP
as i see the SFP here LX,
couple of things we need to check :
1. is this issue you see recently, from the day 1, or is this new link ?
2. do you see any performance issue ? other than logs ?
3. what Mode of cable ? Multi-mode or single mode ?
4. what is the distance between this switch and other end ?
5. what is other end ? switch ? or what device ?
post : (both the sides)
#show inte gig1/0/50 trans det
BB
Right now it is connected to a mikrotik CRS328-4C-20S-4S+
im using the mikrotik mainly because of port density.. Im saving up for an asr920 with 24 sfp por4ts
Below are the two commands..
Thank you
SiteOpsOfficeSw204#show int gig1/0/50
  Keepalive not set
  Last input 00:00:12, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 37
  5 minute input rate 2468000 bits/sec, 453 packets/sec
  5 minute output rate 4347000 bits/sec, 408 packets/sec
     21174785 packets input, 20634037236 bytes, 0 no buffer
     Received 468401 broadcasts (409965 multicasts)
     0 watchdog, 409965 multicast, 0 pause input
     8475123 packets output, 10929839944 bytes, 0 underruns
SiteOpsOfficeSw204#show int gig1/0/50 trans de
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                              High Alarm  High Warn  Low Warn   Low Alarm
          Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Gi1/0/50    32.3                90.0        85.0        -5.0      -10.0
           Voltage            Threshold   Threshold  Threshold  Threshold
Port       (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Gi1/0/50   3.31                  3.70        3.60        3.00       2.90
           Optical            High Alarm  High Warn  Low Warn   Low Alarm
           Transmit Power     Threshold   Threshold  Threshold  Threshold
Port       (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Gi1/0/50    -6.3                 1.0        -3.0        -9.5      -13.5
           Receive Power      Threshold   Threshold  Threshold  Threshold
Gi1/0/50   -23.1         --      1.0        -3.0       -19.0      -23.0
BTW the cable is single mode, and the switch is actually not far away but it is on a premade 1000 ft fiber.
Reza Sharifi
This is a cosmetic error that appears in several different Cisco switches and routers with fiber interfaces. Your interface looks good and clean. Sometimes replacing the SFP, cleaning the fiber connectors helps and sometimes an upgrade will resolve the issue. So, if the message is affecting the interface, open a ticket with Cisco and ask them what could be done.
