01-24-2021 07:12 AM
given below is the error on our secondary side switch 2960X
This fiber(ten1/49-50) is a LAN switch directly connected to dell N4064F switches (LACP).
Because of the below-depicted error on the picture, our WAN connectivity is intermittent between primary and secondary. What causes intermittent whole networks. Please advise me.
(Primary ) SW-----------------WAN link------- (Secondary ) SW
FW(HA) (static to BGP) FW(HA)(OSPF to BGP)
2960X 2960X
|| (LACP) ||(LACP)
N4064F (Dell) N4064F(Dell)
VM VM
Solved! Go to Solution.
01-24-2021 02:53 PM
You may have a bad SFP+ in that port. The other option to look at is to clean the fiber patches with alcohol and see if that makes a difference. Are there any errors on the interfaces (sh interface)?
01-25-2021 01:45 AM
Hello @leyakhath muhammed ,
as suggested cleaning the fiber connectors may likely solve do it at both ends of the RX fiber ( and on remote TX).
To check if one SFP+ may be not working or there is a fiber issue you can create a remote loop connecting the fibers together with a junction if both SFP+ complain the issue may be on the fiber if one SFP+ is up looped and the other ip up looped with alarm on rx power you should change that SFP+.
Hope to help
Giuseppe
01-24-2021 02:53 PM
01-25-2021 01:45 AM
Hope to help
Giuseppe
