same etherchannel grouping on different switch
kokhong.chew
Level 2
Level 2
Can i configure etherchannel and group each respective port on different switches as an etherchannel group ?
Example : 2 C2960 switch separately connected to a C3750
7 Replies 7
Leo Laohoo
No.
thanks
Can configure etherchannel on switchport access mode without vlan tagging ? ?
Do you mean configure the etherchannel as access port with no vlan tag?
Yes, you can do the following on the etherchannel (PO)
switchport mode access
switchport access vlan xyz
jerry
Jerry
only this command "switchport mode access"
without this command "switchport access vlan xyz"
something like trunk mode
Then the untagged vlan will be vlan 1 and this is the default.
jerry
Thanks Jerry
