Same VLAN between multiple switches
Need to add some ports from switch1 and some ports from switch2 in same vlan and also i have to do many vlan on same, please explain the process.
Ramesh
Reza Sharifi
Just create the vlans you want to add the proper ports to it.
example
config t
vlan 20
name test
exit
inter gi1/0/1
switchport
switchport mode access
switchport access vlan 20
and so on..
Also, have a look at this link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_2_se/configuration/guide/3750x_cg/swvlan.pdf
Dennis Mink
Also, make sure you have a trunk between the two switches. there is plenty of documentation out there outlining how to do that.
Please remember to rate useful posts, by clicking on the stars below.
