Same VLan, different IP
Create Share
Hi!
Is it possible to have different vlans and IP addresses for two devices connected to the same switch port?
Thanks.
You can have two devices on different vlans if one is a Cisco phone. Using the switchport voice vlan ### command.
Smitesh is correct if you connected an unmanaged switch or hub you'll only be about to use one vlan.
You could use a trunk to connect a managed switch to another managed switch but I don't think this would work if you connect an unmanaged switch to a trunk port on the managed switch. Although I've never tried this so it may work.
Matt
6 Replies 6
Leo Laohoo
How?  By using a spliter?
cadet alain
if you mean 2 devices in same vlan but in different subnets on same switch then the answer is YES but I wouldn't recommend such a design.
Regards.
Alain.
I guess you thinking about connectivity from switch to some unmanage switch or hub.
However, at switch; port can be configured as access-port for only single VLAN.
Smitesh
Matt
Yes you are right. I have IP Telephone connected to my LAN Cable and then to my pc. There is no unmanaged switch. I need to make IP Telephone and my computer subnet seperate. How can i do that?
Thanks.
you can do it in 2 ways:
1)
    switchport mode access
    switchport access vlan 10
    switchport voice vlan 20
2)
    switchport mode trunk
    switchport trunk native vlan 10
    switchport trunk allowed vlan 10,20
Regards.
Alain.
