Hello
I need a help regarding the next issue:
I have a pair nexus 5548 licensed for SAN, besides of having installed the module 8p 10GE Eth/FCoE + 8p 8/4/2/1G FC each switch, so, both switches are in operation, and i need to move the license and also the FC modules to another pair of switches nexus 5548. What should be the procedure to move the license and the modules to the another pair of switches nexus 5548???
I would appreciate the help with any recommendation and best practice for doing it.
Best regards,
Alexis
Solved! Go to Solution.
Hello Alexs
One additional way to rehost your licenses is to go to http://cisco.com/go/licensing and from the top menu select the "Transfer" option.
There you will find either transfer for RMA or rehost options.
HTH,
Alex
Send an email to licensing@cisco.com with the serial numbers of both Nexus 5K and tell them you want to "port" the license to the second chassis.
Hello Alexs
HTH,
Alex
rehost options
That's the word I've been looking for! "rehost"
Thanks a lot to everyone for the help, i am gonna try using the tool http://cisco.com/go/licensing
Best regards,
Alexis
You're welcome.
Anyway - if you will have any questions ou can follow an option offered by leolaohoo.
Licensing team will be glad to help you.
Alex
