Saving to Flash
joe vieira
Is there a difference between the results of the commands "copy run flash"  or "write mem" ?
Cisco Freak
Level 4
Level 4
Copy run flash will write the running config to the flash memory.
Write memory will put the running config in the nvram.
When the device boots up it will search for the running config in nvram, based on the configuration-register value that you have set.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The former is the newer and recommended command, the latter is the older and, desired to be, deprecated command.  (The latter is likely still available because it's probably still very commonly used and popular.)
