secondary IP add in HSRP
danielyusuf
Hi Experts,
need your opinion. Which one is better.
a. having 3 VLAN with 3 subnets, then routing is done via interface VLAN each
or....
b. having 1 vlan with 3 subnets, then routing is done via ONE interface VLAN while other 2 subnets routed using secondary ip address of the first interface VLAN
any response, gladly appreciated..
thanks
-daniel
Edison Ortiz
The first option is better. On the second option , you have one broadcast domain with 3 different IP subnets.
Broadcast traffic will increase as you will have up to 762 hosts (based on /24 on each subnet).
Again, option one gives you a much better network.
