Hi folks,
If i take off secondary ip address of interface vlan 1, most PCs looses network connection.
All the PC's/Servers are pointing to 172.17.0.250 for their default gateway and have ip address from the same range 172.17.0.0/16
here is what we got.
Two 3750 stacks, serving as core switches for our network. All the workstations (1000) and some servers (20) are on VLAN 1 (I know how this sounds but beleive me it wasn't me who designed it and i am currentlly in a process to segment that).Sswitch1, under interface vlan 1 we two address. Please find config below
Switch 1
interface Vlan1
ip address 195.69.0.253 255.255.255.0 secondary
ip address 172.17.0.234 255.255.0.0
ip helper-address 10.0.17.2
ip helper-address 10.8.4.1
no ip redirects
ip directed-broadcast 101
ip pim dense-mode
ip igmp query-interval 125
ntp broadcast client
standby 11 ip 172.17.0.250
standby 11 ip 195.69.0.250 secondary
standby 11 priority 110
standby 11 preempt
end
Switch 2
interface Vlan1
ip address 172.17.0.233 255.255.0.0
ip helper-address 10.8.4.6
ip helper-address 10.0.17.62
no ip redirects
ip pim dense-mode
standby 11 preempt
end
Thank you in advance for comments and suggestions
Walana
"Love is the bridge between you and everything" - Rumi
