Seconday power supply on 9300L: instead of "Unknown" define it as "Not
Andrey128
On access switches 9300L we do not purchase and not installing secondary power supplies. Because of that, such switches generating fals alarms towards monitoring system. Is there any command setting or other workaround to change status of power supply from this one ("Unknown"):
#show environment power
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  PWR-C1-715WAC-P     12345678DMH  OK              Good     Good     715
1B  Unknown             Unknown      Disabled        Bad      Bad      Unknown
to this one ("Not present"):
1A  Not Present
1B  PWR-C1-715WAC-P     DCC54321CSTZ  OK              Good     Good     715
Or other solution to disable reporting by switch absence of secondary power supply...
5 Replies 5
Leo Laohoo
What firmware is the stack on?
-firmware is 16.12.05b
- switch is standalone, no stacking
Do not use 16.12.X because the entire train is buggy.
marce1000
 - FYI :  https://bst.cloudapps.cisco.com/bugsearch/bug/CSCue24256  , use latest advisory release https://software.cisco.com/download/home/286322037/type/282046477/release/Bengaluru-17.6.4 , check if that can help  ,
 M.
thanks, I will check,
as I understand, firmware versions 17.x.x are for SDA-type network ?!
