Cisco 6509 tacacs authentication problem
ROHIT SHARMA
Hello Friends,
I have a Cisco 6509 switch running Version 12.2(33)SXI7 configured aaa new-model.
I have 2 tacacs+ servers configured for authentication.
When I test the authentication using the "test aaa" command it works fine and the authentication result is successful, but when I actually try to log in via SSH, the same user its not able to authenticate and keeps asking for the password.
I captured packets on the uplink interface and could see that for the "test aaa" command, the switch was sending tacacs+ authentication packets to the aaa server, but when I actually try to log in, it wasn't sending any such request.
It's a very weird issue and I am thinking if it could be due to some stuck process or any other issue which could be resolved by a reboot. the switch has been up for 10 years now.
Any help would be much appreciated.
Mark Elsen
           - Check logs on the 6509 when the SSH is tried , and also the aaa server (TACACS) logs ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
It doesn't show anything in the logs when I attempt to login. Any other ideas please?
