Secure LACP Interface
rbncarvalho
Level 3
Level 3
Hi all,
Does anyone know any alternative to port-security or dot1x to secure interfaces.
We're trying to secure interfaces connected to 1850 Access Points, but the catch is that we're using LACP, so port-security and 802.1x isn't supported.
The access box is a 2960X.
Thank you
Best Regards,
Please rate helpful posts,
Ruben Carvalho CCIE#57952
EduardR
Level 5
Level 5
What version are you running in your Catalyst? I've tested on one 2960X stack with a portchannel and it is possible to configure port-security on the port channel. Also, the oficial documentation says: "Port security supports access and trunking EtherChannel port-channel interfaces."
EduardR
Level 5
Level 5
