Cisco Nexus 7009
amey.dixit
Hi guys,
is there any challenge to upgrade core switch 6500 series from Nexus 7009 which runs NxOS, because i have 3750X series switches connected at distribution and access layer in my network topology??
I only want to ask you guys is there any planned way to do this activity?? is there any challenge if we place NxOS in core and IOS in distribution and Access layer??? how we are able to match sh run config in existing 6500 switch to Nexus 7009 NXOS???
Quick reply appericiated.
Amey
10 Replies 10
mahmoodmkl
Level 7
Level 7
Can you please clarify what exactly your are trying to achieve as the above is not clear.
amey.dixit
Basically we need to upgrade core 6500 series from Nexus7009 chassis.
Nexus series run on nxos and after up gradation I have 3750 series at my access layer which runs ios.. So is there any comparability issue..
There is no compatibility issue.
Oleksandr Nesterov
Hi Amey
from the perspective of physical interconnection - no incompatibilities.
from the perspective of functionality - both IOS switches and NX-OS switches comply with network standarts, RFC's etc.. so will work perfectly together and ill work even with 3rd party devices which also follow thesandarts.
From the configuration perspectiv wolud sugges you to read following links:
http://docwiki.cisco.com/wiki/Catalyst_to_Nexus_Migration
http://docwiki.cisco.com/wiki/Cisco_NX-OS/IOS_Software_Default_Configuration_Differences
http://www.netcraftsmen.net/component/content/article/69-data-center/807-migrating-to-nexus-7000-from-catalyst-6500-and-4500-switches.html
As some default states and config commands may differ from IOS.
HTH,
Alex
Thanks Alex,
I will surely look your pasted links from configuration perspective.
that will be appreciated, if you have any link which commits Planning( which we need to be done before Migration) or plan of action during migration from Cat6500 to nexus 7009.
Looking forward to see your reply.
HTH,
AmeyD
amey.dixit
Thanks Alan
patrick.preuss
Why relplace The 6500 ? Chassis and The T2 Engine will be supported at least 5 years.
T2 brings a Lot of Performance.
With nx-os you will lose some Features no Service Modules.
If you are Not Planing for fcoe 6500 are still valid.
amey.dixit
Thanks Patrick for your valuable views
But this time we look for FCOE, because we are migrating our SAN on to it.
According to you, no service module is supported in nexus 7k ??
Amey
There are service modules for Nexus 7000 - ACE for example :
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/solution_overview_c22-643591.html
But you need to reach your account team to get more info about which other services modules will be available on Nexus platform.
Also you can itegrate cat6k with N7k and use service modules on cat6k.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/nx_7000_dc.html
But again you need to reach your Cisco Account team and get advices from them to understand which better suits your network needs.
Alex
