Secure Shell
innojohn69
Level 2
Level 2
I am really disturbed by the SSH connection on my lab. I am trying to login in but it gives me the error below. I am using the putty software.
login as: JIN_ROUTER2
[email protected]'s password:
Access denied
Access denied
Any advise?
Thank you.
2 Accepted Solutions
Philip D'Ath
Meraki Community All-Star
Have you configured AAA?
aaa new-model
aaa authentication login default local
aaa authorization exec default local
Philip D'Ath
This configures it to use the local username/password database for authentication.
It would be great if you could mark my answer as correct.
7 Replies 7
Philip D'Ath
It is simply saying that you are using the wrong username and password.
But, I have the username as I set it up on the configuration, and the password is correct too.on the hostname i used the the fa0/1 int ip address.
Philip D'Ath
aaa new-model
Not yet.What does this configuration
help ? Thank you.
Hi, Philip, Thank you very much. This seems to make it work. I am still learning these things and I am always eager to learn new things. I have never used ssh before. But, your configs up here works. Please educate me a bit about them. Thank you again.
Philip D'Ath
