Sending messages to other users
Mike_Gannon
I was practising on a CLI in a lab the other day when a tutor simultaneously logged onto the router and sent me a message through the CLI. I did not know how to reply. Does anybody have an idea how this is done (or whether it was just a feature of the lab set up)
Thanks for you help
Mike
Jon Marshall
Mike
It is done with the "send" command. You need to know the line that the person is on to send a message eg.
R1#who
Line User Host(s) Idle Location
* 0 con 0 idle 00:00:00
66 vty 0 idle 00:00:02 192.168.5.2
Interface User Mode Idle Peer Address
So if you wanted to send a message to the user on vty 66
1) R1# send 66 - and then hit return
2) You will be prompted to type in a message and then hit Ctrl-C or Ctrl-Z
3) The message will then appear on the person console screen.
Jon
glen.grant
Or you can send it to everyone who is using a vty session on the device if you don't know the particular vty session though I think you can determine that with a "show user" or show line command. It fun to mess around with people who don't the command. :-)
