serial port conection
garaza
Community Member
i just needs to know can i use smart serial port on one side and stander serial port on the other side I am using 1841 with smart serial and 2600 with standered  serial port any one help pls I am just started CCNA I just needs for my practice?
Reza Sharifi
Yes, you can connect them back to back.
You need this cable
http://www.ebay.com/itm/like/251421683744?lpid=82&chn=ps&ul_noapp=true
