server connected to switch port but no traffic passing through
linqksupport
this is really embarrassing and has been frustrating to say the least.
I have a linux (centos 5) machine which has eth1 connected to a port on a Cisco 3560G. The switch port belongs to a VLAN which is public. It appears that this linux machine is actually connected to this port (I am not physically there...this equipment is sitting on the other side of the world, I'm VPN'ing).
If I shutdown the interface Gi0/20 to which this machine is apparently connected and use "ip monitor" or "mii-tool -w eth1" on the linux machine, I see the tranisition happen with the link dropping. The same happens the other way, if I shutdown eth1, I see the interface going down on the switch console.
I have statically assigned an available IP address from our pool to eth1 which belongs to the VLAN on Gi0/20, but for the life of me I cannot understand why I can't get any traffic going anywhere.
The routing table in the linux machine has been done and re-done and regardless of that, I should see the MAC address of the switch show in the arp cache of the linux machine. Incidentally the mac addr of eth1 does show up on the switch "sh mac address-table interface Gi0/20" when I turn it up or down, but after a little while it disappears from the switch arp table.
I haven't touched the cisco stuff for a while and have forgotten everything. Can't figure out how to troubleshoot this:
have tried ping (obv), traceroute, traceroute mac, traceroute mac ip etc. but doesn't come up with anything. It's as if the switch doesn't even know about this machine.
Please help...I've wasted 2 whole days on this and it's really annoying esp. when the machines are so far away and the response time and interaction with the network takes so damn long
Thanks in advance
8 Replies 8
Please paste the output of "show int gig 0/20 switchport". Is the VLAN really the one you want to use?
If yes, take another free IP and configure the IP with:
interface vlan VLAN
ip add ...
Can you ping that IP from the PC?
And paste the output of "sh run int gig 0/20".
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Hi. Please see below the output you requested:
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Access Mode VLAN: 100 (EXTERNAL_VLAN)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Yes...although I tried changing VLANs on this port to other available VLANs on this switch
and changing eth1 correspondingly, but I get the same behaviour.
interface vlan VLAN
ip add ...
No I can't ping anything from the PC, either this or anything else on the same VLAN. Like I said,
even the arp cache expunges the record for the mac of this interface after a short time, so no one
on the network has any clue about this Interface. The only signs I see are when you either shutdown
Gi0/20 and monitor the state change on the linux box or vice-versa. So we know that they are indeed
connected but why nothing else is going on, I have no clue
interface GigabitEthernet0/20
description EMS00 - LNK A
switchport access vlan 100
priority-queue out
spanning-tree portfast
end
You're connected via vpn on the linux device via a second port? I can't visualize your setup
The linux machine in question is part of a much larger network..I'm VPN'ed into that network ...
have access to the switch via a serial console switch
have access to the linux console via a remote supervisor adapter so I can turn networking on/off / add/remove ethernet ports etc.
Hi there
Can you paste the output from the following commands?
Sh ip arp vlan 100
Sh run int vlan 100
Sh ip int brief
The switchport looks ok. For best practice you should configure "switchport host" on the port.
Can you replace the server against anything else to see how a different device works on that port? Can the server work on a different switch?
Hi. Ok thanks for the advice on "switchport host" ...I don't know what it does but I'm assuming it tells the switch that the port is connected to a physical machine as opposed to another switch?
No I can't replace it or do anything that requires a physical change. As explained earlier, these servers are over 8,000 miles away or switching out the server with something else on that switch port would've been the first thing I'd have tried
After having conducted further investigation on the Linux machine, I am sure something is definitely wrong with that NIC on that machine. This machine is equipped with 2 x Dual GigE NICs. The 2 NICs are NOT identifcal (not the same model). The 2nd port of this NIC is connected to a different switch in a different VLAN. I turned that up, configured it etc. and it has the exact same problem
The loopback test of the offline ethtool test fails on both ports of this NIC with code "13", turns out this indicates that the hardware MAY be failing. These NICs have really old NIC e1000 driver versions. I will download the latest drivers for it, and run the test again at a later time as after having spent countless hours on it I have put in some workarounds in place for me to use the machine for the purpose I turned it back up (for now). Just scared that messing around with drivers and the sort may not go well (knowing my luck).
From the reference:
To optimize the port for a host connection, the switchport host command sets switch port mode to access, enables spanning tree Port Fast, and disables channel grouping. Only an end station can accept this configuration.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750/software/release/12.2_55_se/commmand/reference/cli3.html#wp1948119
