Service Provider Connection - Uplink 10gigE Circuit
packetzen
I have a new Internet Connection (my 6513 will be a Internet Router) using 10GigE connection.  The port is up and linking at 10Gig.  I have my ip and the other 'side's' ip address.  My question is what are the advantages disadvantages to the following:  I configure the 10gigE Inter with the ip address.  Or create a L3 SVI with the associated ip address.  My guess is create the L3 int. A little basic I know but it's not very clear in my mind.  I think both would work w/o issue.
Thanks!
Giuseppe Larosa
Hello PacketZen,
using the routed interface approach STP plays no role
if you use an SVI, STP plays a role
The use of SVIs can be an advantage if:
multiple physical links exist in the same broadcast domain / IP subnet
or if you need multiple logical interfaces you can emulate router Vlan based subinterfaces using a L2 trunk + SVIs one for each logical interface
In your case using a routed interface is probably the best choice
Hope to help
Giuseppe
