12-11-2012 06:09 AM - edited 03-07-2019 10:32 AM
I just checked that PBR with setting ip default next-hop is not available on cat 3750.
Does anyone know if there is another way to do dual-homing ISP without this feature?
Johnny
Solved! Go to Solution.
12-11-2012 07:25 AM
You could use "set ip next-hop", but when that hop is down it's not going to roll over. I don't believe the 3750 supports verify-availability either. You could possibly use eem to do something creative such as modifying your policy map should a route drop out of the table.
HTH,
John
*** Please rate all useful posts ***
12-11-2012 06:25 AM
What version ios are you running? I have the option on mine:
Switch(config-route-map)#set ip default next-hop ?
A.B.C.D Default next hop IP address
verify-availability Verify if default nexthop is a CDP neighbor
Version 12.2(44)SE5
HTH,
John
12-11-2012 06:29 AM
you can configure set ip default next-hope but when you appli the policy to an interface it's refused.
3750 doesn't support set ip default next-hop
12-11-2012 06:35 AM
Policy routing in general isn't supported if your sdm template isn't configured for routing:
You can do a "show sdm prefer" to see what your current template is set for.
HTH,
John
12-11-2012 06:41 AM
yes SDM template was configured to routing and the switch rebooted. IOS is ip service.
The problem is that ip default next-hop is not supported on cat 3750
12-11-2012 06:47 AM
I just found this:
That's new to me...sorry for sending you on a goose chase. Okay, what is it you're trying to accomplish?
HTH,
John
12-11-2012 06:49 AM
I need some vlan to reach internet from a dafault gateway A
and other vlan to reach internet from a default gateway B
12-11-2012 07:25 AM
HTH,
John
12-11-2012 09:00 AM
I think I solved this way (hope it's fine):
I have my local subnet for istance (10.1.0.0/16 , 10.2.0.0/16, 10.60.0.0/16) which are routed by 3750 SVIs and access internet by the default route 0/0 10.60.0.253. and these are ok.
I also have traffic coming from a wan (subnets 10.70.0.0, 10.20.0.0) that need to reach my local subnets and access internet by a secondary fairewall (10.60.0.250).
so in the interface where my wan is connected i configured the following policy:
ip policy route-map PBR
route-map PBR permit 10
match ip address LOCAL
route-map PBR permit 20
set ip next-ho 10.60.0.250
IP access-list extende LOCAL
permit ip 10.0.0.0 0.255.255.255. 10.0.0.0 0.255.255.255
the statement 10 simply match communication patterns between local and private subnets and let them reach each other. (there is no set configured)
the statement 20 simply match all other traffic a (there is no acess-list) and set next-hop to the secondary firewall.
I tested it and seems to work. what do you think about?
Thanks to all for your collaboration.
Jhonny
12-11-2012 09:06 AM
also I don't need any fall-back mechanism in case of secondary or primary firewall failure.
12-11-2012 09:07 AM
That's a good way to do it...if it's working, that's awesome It's sometimes hard to get around issues when your hardware/ios doesn't support it.
HTH,
John
