vss standby chassis reboot trap
raindrop18
I have multiple 6509 vss switch. and i notice when the standby chassis reboot I didn't get any snmp trap, but I got when the active one reboot. my question is is there any mib out there for detecting and got a trap when standby reboot? thanks.
Reza Sharifi
Have you tried this command?
snmp-server enable traps vswitch
thanks for the response. yes I have the following commands on my config.
snmp-server enable traps vswitch vsl
so that only work for dual active or both the active and the standby failed.. as I said I am looking for for theses 2
Active Supervisor Engine Failure (=Active Virtual Switch Chassis Failure)
Hot-standby Supervisor Engine Failure (=Standby Virtual Switch Chassis Failure)
thanks.
