Setting 10G Breakout on a CVR-QSFP-SFP10G daughter card
jangel
We have an older 6509 chassis with WS-F6K-DFC4-E module installed.  The 6509 is EoL, EoS and is slated to be replaced shortly.  However, we still need to add additional 10G connections before the hardware can be replaced.  When we added the additional WS-F6K-DFC4-E module, it defaulted to it's 40G configuration.  Documentation for breakout the 10G ports looks like this..."switch(configure)# interface breakout module 1 port 12 map 10g-4x".  However, when I get to the command line to set the breakout command, breakout is not offered as a command option, "
BN-Replication_6509(config)#interface break?
% Unrecognized command
Any recommendations or older documentation that I'm missing?
Thanks!
jangel
Probably should have included this info:
Version 15.1(2)SY3
Try loading this version.
CVR-4SFP10G-QSFP
4 x SFP10G to QSFP Reverse Adapter
15.3(1)SY
