Setting a root bridge when using MST
ngthen
Level 3
Level 3
I am running MST on my network with 1 instance right now but will soon be 2.  If I issue the show spanning-tree command here is what I see:
MIB-SW-CORE-01#show spanning-tree
MST0
  Spanning tree enabled protocol mstp
  Root ID    Priority    32768
             Address     000d.2908.3b80
             Cost        0
             Port        3 (GigabitEthernet0/3)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32768  (priority 32768 sys-id-ext 0)
             Address     000f.23c1.d100
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/1               Desg FWD 20000     128.1    P2p
Gi0/2               Desg FWD 20000     128.2    P2p
Gi0/3               Root FWD 20000     128.3    P2p Pre-STD-Rx
Gi0/4               Desg FWD 20000     128.4    P2p
Gi0/11              Desg FWD 200000    128.11   P2p Edge
Gi0/12              Desg FWD 200000    128.12   P2p Edge
MST1
  Root ID    Priority    32769
             Cost        20000
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
Is there a reason that my CORE switch is not showing up as the root even through I have the following?
spanning-tree mode mst
spanning-tree logging
spanning-tree portfast bpduguard default
spanning-tree mst configuration
name mib-mstp
revision 1
instance 1 vlan 1, 8, 13-14, 17, 151-152
spanning-tree vlan 1,8,13-14,17,151-152 priority 8192
cadet alain
This is not for MST.
The correct syntax is span mst 1 priority 8192
Regards.
Alain.
cadet alain
Regards.
Alain.
