setting ACL in switch l3
Roza12
i have guest vlan 50 192.168.50.0/24
servers in subnet 172.20.1.0/24
and i want to allow quest vlan to access  from this range of servers (172.20.1.0/24) only
1-dhcp server (172.20.1.100,172.20.1.101)
2-dns, (172.20.1.115,172.20.1.116)
3- other 4 servers using ports 443/80
 then deny access to the rest of the servers in range 172.20.1.0/24
The rest should just be open, so would ASA be able to control access to DMZ, etc.  :
then permit access to internet or permit any any
so please your help , how should i do that without making any errors ?
22 Replies 22
For DHCP and DNS I only allowed bootpc and domain
My goal is to prevent any Guest IP from accessing all servers except 4 servers
If I want to deny access from servers to the guest I should do
Deny ip  172.20.1.0 0.0.0.255 193.168.50.0 0.0.0.255
Yes, adding that deny statement after your specific permit statements (for DHCP, DNS, etc) will give you that result.
Cheers,
Seb.
Last question
Regarding to DHCP:-
What's the difference between below commands , which one would be better for use
 permit udp 192.168.50.0 0.0.0.255 host 172.20.1.100 eq bootpc
permit udp 192.168.50.0 0.0.0.255 host 172.20.1.101 eq bootpc
And
permit udp any any eq bootps
Hello
The you should filter the access from the server vlan NOT the guest vlan
example:
ip access-list extended guestvlan_access
permit tcp 192.168.50.0 0.0.0.255 host 172.20.1.100 range www 443
permit udp 192.168.50.0 0.0.0.255 host 172.20.1.100 range domain bootpc bootps
permit tcp 192.168.50.0 0.0.0.255 host 172.20.1.101 range www 443
permit udp 192.168.50.0 0.0.0.255 host 172.20.1.101 range domain bootpc bootps
permit tcp 192.168.50.0 0.0.0.255 host 172.20.1.115 range www 443
permit udp 192.168.50.0 0.0.0.255 host 172.20.1.115 eq domain
permit tcp 192.168.50.0 0.0.0.255 host 172.20.1.116 range www 443
permit udp 192.168.50.0 0.0.0.255 host 172.20.1.116 eq domain
deny ip 192.160.50.0 0.0.0.255 any
permit ip any any
int vlan xx
description Server vlan
ip access-group guestvlan_access  OUT
Kind Regards
Paul
Why out ???
From guest going to server so it should be in am I right???
Hello
@Roza12 wrote:
Why out ???
SVI acl  logic
IN= originating from within vlan going out
OUT = originating from outside the vlan coming in
Kind Regards
Paul
Nicely summarized. Thanks for this.
Paul, with all respect it is best practice to filter traffic as close to the source as possible, hence suggesting an inbound ACL on the guest_vlan SVI.
Cheers,
Seb.
