Setting up a trunk over two 2950s
littlegiglow
I have two 2950 switches. I am trying to set up a trunk over fa0/1 on both switches. There are no lights on the ports when I connect a cross-over cable. Any suggestions would help. I used the following commands on my first switch (Texas):
en
config t
int fa0/1
switchport mode trunk
speed 100
duplex full
switch two (Arkansas)
en
config t
int fa0/1
switchport mode dynamic
speed 100
duplex full
Texas#show int fa0/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Protected: false
Voice VLAN: none (Inactive)
Appliance trust: none
Arkansas#show int fa0/1 switchport
Switchport: Enabled
Administrative Mode: dynamic desirable
Protected: false
Arkansas#sho int fa0/1 trunk
Port Mode Encapsulation Status Native vlan
Fa0/1 desirable 802.1q not-trunking 1
Texas#show int fa0/1 trunk
Fa0/1 on 802.1q not-trunking 1
On your Switch2
Change the configuration to Switchport mode trunk like you did in Switch1 so your Switch2 will have this config
en
config t
int fa0/1
speed 100
duplex full
connect both switches Fa 0/1 with cross-over and you should see the trunk link comeup green.
Hope This Helps
Shaheen
glen.grant
Make both ports "switchport mode dynamic desirable" and let the switch negotiate the trunk this way you will know that the trunk is working correctly.
craig.eyre
Did you get this figured out?
What version of IOS are you running?
Craig
