setting up vrf in router 2911 and distribution switch 3560G catalyst
I have 50Mbps from ISP and i want to split into 5 client's each 10Mbps from router to distribution switch catalyst 3560G via vlan
int gig0/0 - ISP
int gig0/1 - to port 22 on SwitchCore under vlan 5
int gig0/1.10 - Client-2
int gig0/1.11 - Client-1
I can't get out to internet
What config i miss?
I configured in this way on R1:
ip vrf Client-1
rd 11.11.11.5:11
ip vrf Client-2
rd 11.11.11.1:10
______________________________
interface GigabitEthernet0/0
description *** ISP PiPe ***
ip address 125.212.50.54 255.255.255.252
duplex full
speed auto
interface GigabitEthernet0/1
description *** LAN PiPe ***
ip address 121.97.65.61 255.255.255.240
duplex full
speed 1000
interface GigabitEthernet0/1.10
description Client-2
bandwidth 10000
encapsulation dot1Q 10
ip vrf forwarding Client-2
ip address 11.11.11.1 255.255.255.252
no ip redirects
no ip proxy-arp
rate-limit input 10000000 3750000 3750000 conform-action transmit exceed-action drop
rate-limit output 10000000 3750000 3750000 conform-action transmit exceed-action drop
no cdp enable
interface GigabitEthernet0/1.11
description Client-1
bandwidth 10000
encapsulation dot1Q 11
ip vrf forwarding Client-1
ip address 11.11.11.5 255.255.255.252
no ip redirects
no ip proxy-arp
no cdp enable
ip route 0.0.0.0 0.0.0.0 125.212.50.53
I configured in this way on catalyst 3560G:  <--- this switch is already exist on the network i just use this to maximized the equipments
SwitchCore#show run
Building configuration...
Current configuration : 8467 bytes
version 12.2
no service pad
service password-encryption
hostname SwitchCore
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone CST 8
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip routing
no ip domain-lookup
ip domain-name mydomain.com
spanning-tree mode pvst
spanning-tree vlan 1,99-114,200-210 priority 24576
vlan internal allocation policy ascending
vlan 5
name ISP PiPe
vlan 10
name Client-2
vlan 11
name Client-1
vlan 99
name vlan-name
vlan 100
name vlan-name
vlan 200
name vlan-name
interface GigabitEthernet0/19
description *** Client-1 ***
switchport access vlan 11
switchport mode access
interface GigabitEthernet0/20
description *** Client-2 ***
switchport access vlan 10
interface GigabitEthernet0/22
switchport access vlan 5
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan5
description Connected-From-R1_ISP_PiPe
ip address 121.97.65.62 255.255.255.240
interface Vlan10
interface Vlan11
interface Vlan99
description *** vlan-name ***
ip address 192.168.99.2 255.255.255.0
interface Vlan100
ip address 10.10.2.2 255.255.255.128
interface Vlan200
ip address 10.10.0.3 255.255.254.0
ip default-gateway 192.168.1.1
ip classless
ip route 10.10.0.0 255.255.254.0 192.168.1.1
ip route 11.11.0.0 255.255.254.0 121.97.65.161
no ip http server
5 Accepted Solutions
Bilal Nawaz
Hello, there are no default routes for your VRFs
If you do show ip route vrf Client-1 and same for 2 I do not think you will see the default route. You need to tell the VRF to use the global routing table.
E.g. Ip route vrf Client-1 0.0.0.0 0.0.0.0 x.x.x.x global
and also noted duplicate IPs on the router and the switch. Is this correct? Is there a trunk from the switch to the router?
You do not need ip default-gateway on the switch. Because it has more than 1 svi you need to set the static default route instead like ip route 0.0.0.0 0.0.0.0 x.x.x.x
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
I think i've come up with a solution for you. We'll have to use VRF's if you want overlapping addresses. I'll try to demonstrate with this example here:
Here I have switch 1 where my clients are connected - I am only showing a PC who is client 1 with an IP of 11.11.11.100.
It has a default gateway of the VRF which is 11.11.11.1 on R1.
I am doing 'router on a stick' - this involves creating sub-interfaces on the router with the correct encapsulation and a trunk being configured on SW1.
Wherever my clients are connected I just have to put them in the right VLAN.
lets say client is connected to the SW1 on fa1/11.
The configuration would be:
interface fa1/11
switchport
just a simple access port. Please NOTE: I have not configured any addresses on the switch! its only doing my Layer 2. I'll leave all the hard work for the router to do - router's are built to route :-)
Here is the configuration of SW1:
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
description UPLINK TO R1
switchport trunk allowed vlan 1-5,1002-1005
switchport mode trunk
duplex full
speed 100
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
description CLIENT-1
switchport
interface FastEthernet1/12
description CLIENT-2
switchport
switchport access vlan 2
interface FastEthernet1/13
description CLIENT-3
switchport
switchport access vlan 3
interface FastEthernet1/14
description CLIENT-4
switchport
switchport access vlan 4
interface FastEthernet1/15
description CLIENT-5
switchport
SW1#show vlan
VLAN Name                             Status    Ports
1    default                               active    Fa1/11
2    VLAN0002                         active    Fa1/12
3    VLAN0003                         active    Fa1/13
4    VLAN0004                         active    Fa1/14
5    VLAN0005                         active    Fa1/15
Just a simple config with my layer 2 in place.
No routes needed, no SVI interfaces needed.
Lets go over to R1 where the VRF magic happens.
R1#show run
Current configuration : 2387 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf client-1
rd 1:11
ip vrf client-2
rd 2:22
ip vrf client-3
rd 3:33
ip vrf client-4
rd 4:44
ip vrf client-5
rd 5:55
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no ip address
speed 100
full-duplex
interface FastEthernet0/1.11
encapsulation dot1Q 1 native
ip vrf forwarding client-1
ip address 11.11.11.1 255.255.255.0
ip nat inside
rate-limit input 10000000 5000 5000 conform-action transmit exceed-action drop
rate-limit output 10000000 5000 5000 conform-action transmit exceed-action drop
interface FastEthernet0/1.22
encapsulation dot1Q 2
ip vrf forwarding client-2
ip address 22.22.22.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.33
encapsulation dot1Q 3
ip vrf forwarding client-3
ip address 33.33.33.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.44
encapsulation dot1Q 4
ip vrf forwarding client-4
ip address 44.44.44.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.55
encapsulation dot1Q 5
ip vrf forwarding client-5
ip address 55.55.55.1 255.255.255.0
ip nat inside
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route vrf client-1 0.0.0.0 0.0.0.0 125.212.50.53 global
ip route vrf client-2 0.0.0.0 0.0.0.0 125.212.50.53 global
ip route vrf client-3 0.0.0.0 0.0.0.0 125.212.50.53 global
ip route vrf client-4 0.0.0.0 0.0.0.0 125.212.50.53 global
ip route vrf client-5 0.0.0.0 0.0.0.0 125.212.50.53 global
ip nat inside source list MY_NAT interface FastEthernet0/0 vrf client-1 overload
ip nat inside source list MY_NAT interface FastEthernet0/0 vrf client-2 overload
ip nat inside source list MY_NAT interface FastEthernet0/0 vrf client-3 overload
ip nat inside source list MY_NAT interface FastEthernet0/0 vrf client-4 overload
ip nat inside source list MY_NAT interface FastEthernet0/0 vrf client-5 overload
ip access-list extended MY_NAT
permit ip any any
This configuration will allow you to have a default route to the global routing table and be allowed to route out towards the internet. It's important to remember NAT. And I have included the relevant configuration for NAT for all of your VRF's
GLOBAL ROUTING TABLE:
R1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 125.212.50.53 to network 0.0.0.0
     125.0.0.0/30 is subnetted, 1 subnets
C       125.212.50.52 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 [1/0] via 125.212.50.53
VRF ROUTING TABLE FOR CLIENT-1
R1#show ip route vrf client-1
Routing Table: client-1
     11.0.0.0/24 is subnetted, 1 subnets
C       11.11.11.0 is directly connected, FastEthernet0/1.11
As you can see the default route has been introduced to the routing table - I want to try and ping outbound from this VRF just to see if I can get to that 100.0.0.1 address out in the internet....
R1#ping vrf client-1 100.0.0.1
Sending 5, 100-byte ICMP Echos to 100.0.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/20/24 ms
R1#
*Mar  1 00:43:18.795: NAT: s=11.11.11.1->125.212.50.54, d=100.0.0.1 [15]
*Mar  1 00:43:18.811: NAT*: s=100.0.0.1, d=125.212.50.54->11.11.11.1 [15]
*Mar  1 00:43:18.815: NAT: s=11.11.11.1->125.212.50.54, d=100.0.0.1 [16]
*Mar  1 00:43:18.831: NAT*: s=100.0.0.1, d=125.212.50.54->11.11.11.1 [16]
*Mar  1 00:43:18.831: NAT: s=11.11.11.1->125.212.50.54, d=100.0.0.1 [17]
*Mar  1 00:43:18.851: NAT*: s=100.0.0.1, d=125.212.50.54->11.11.11.1 [17]
*Mar  1 00:43:18.855: NAT: s=11.11.11.1->125.212.50.54, d=100.0.0.1 [18]
*Mar  1 00:43:18.875: NAT*: s=100.0.0.1, d=125.212.50.54->11.11.11.1 [18]
*Mar  1 00:43:18.879: NAT: s=11.11.11.1->125.212.50.54, d=100.0.0.1 [19]
*Mar  1 00:43:18.891: NAT*: s=100.0.0.1, d=125.212.50.54->11.11.11.1 [19]
As you can see - the ping was successful and NAT took place and correctly translated the VRF's address. Lets look at it from the INTERNET router's perspective. This time I'll try to ping the 10.0.0.1 address from the client.
INTERNET#
*Mar  1 01:32:05.239: IP: tableid=0, s=125.212.50.54 (FastEthernet0/0), d=10.0.0.1 (Loopback1), routed via RIB
*Mar  1 01:32:05.239: IP: s=125.212.50.54 (FastEthernet0/0), d=10.0.0.1, len 100, rcvd 4
*Mar  1 01:32:05.243: IP: tableid=0, s=10.0.0.1 (local), d=125.212.50.54 (FastEthernet0/0), routed via FIB
*Mar  1 01:32:05.243: IP: s=10.0.0.1 (local), d=125.212.50.54 (FastEthernet0/0), len 100, sending
*Mar  1 01:32:05.263: IP: tableid=0, s=125.212.50.54 (FastEthernet0/0), d=10.0.0.1 (Loopback1), routed via RIB
*Mar  1 01:32:05.263: IP: s=125.212.50.54 (FastEthernet0/0), d=10.0.0.1, len 100, rcvd 4
*Mar  1 01:32:05.263: IP: tableid=0, s=10.0.0.1 (local), d=125.212.50.54 (FastEthernet0/0), routed via FIB
*Mar  1 01:32:05.267: IP: s=10.0.0.1 (local), d=125.212.50.54 (FastEthernet0/0), len 100, sending
*Mar  1 01:32:05.307: IP: tableid=0, s=125.212.50.54 (FastEthernet0/0), d=10.0.0.1 (Loopback1), routed via RIB
*Mar  1 01:32:05.307: IP: s=125.212.50.54 (FastEthernet0/0), d=10.0.0.1, len 100, rcvd 4
So INTERNET router see's the NAT traffic from 125.212.50.54 which is good, because it will reply back to our WAN address - we are able to ping the 10.0.0.1 address successfully.
When I try to ping from client 1 to client 2 - I have no route to get to it and it should fail, so I'll test this:
R1#ping vrf client-1 22.22.22.1
Sending 5, 100-byte ICMP Echos to 22.22.22.1, timeout is 2 seconds:
U.U.U
Success rate is 0 percent (0/5)
R1#
*Mar  1 00:58:17.819: NAT: s=11.11.11.1->125.212.50.54, d=22.22.22.1 [25]
*Mar  1 00:58:17.839: NAT: s=125.212.50.53, d=125.212.50.54->11.11.11.1 [17]
*Mar  1 00:58:17.843: NAT: s=11.11.11.1->125.212.50.54, d=22.22.22.1 [26]
*Mar  1 00:58:19.839: NAT: s=11.11.11.1->125.212.50.54, d=22.22.22.1 [27]
*Mar  1 00:58:19.855: NAT: s=125.212.50.53, d=125.212.50.54->11.11.11.1 [18]
*Mar  1 00:58:19.855: NAT: s=11.11.11.1->125.212.50.54, d=22.22.22.1 [28]
*Mar  1 00:58:21.855: NAT: s=11.11.11.1->125.212.50.54, d=22.22.22.1 [29]
*Mar  1 00:58:21.887: NAT: s=125.212.50.53, d=125.212.50.54->11.11.11.1 [19]
It tries to use the default route - hence why we see the NAT attempts, but will not be able to get there so it fails!
So in summary
  1. your clients should have the default gateway of the VRF address
  2. you need to have a trunk from your switch to the router instead of a routed interface or access port
  3. make sure that the SVI's for these client vlans do not exist on the switch (for the client vlans, the switch should only be layer 2)!
  4. simple access port required for clients - just like your config too
  5. ensure default route exist within the routing table
  6. create the routes for your vrf's pointing to the global routing table
  7. create the acl for NAT and the NAT statements to correctly NAT outbound traffic
Quite a bit to take in - if you have any questions about this, i'll be happy to help!
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Message was edited by: Bilal Nawaz
Hello - I'm glad that the solution worked for you! I was unsure if I explained well enough, but seems as though you got the hang of the method!
You can try to Police the traffic instead of rate-limiting on the sub-if's.
E.g. at the moment we have this:
ip nat inside
So what we can do instead is this:
conf t
ip access-list extended LIMIT_10MB
permit ip any any
class-map match-any LIMIT_10MB
match access-group name LIMIT_10MB
Policy-map LIMIT_10MB
class LIMIT_10MB
  police 10000000 conform-action transmit  exceed-action drop
no rate-limit input 10000000 5000 5000 conform-action transmit exceed-action drop
no rate-limit output 10000000 5000 5000 conform-action transmit exceed-action drop
service-policy input LIMIT_10MB
service-policy output LIMIT_10MB
In your case the interfaces are different. Then save the config and test your speed again.
This will police all your traffic to 9.765625 Mbits.
Hope this helps.
1) Leave it as it is. the config is Additional config!
2) you can limit on each sub interface as I suggested in my post with these commands below:
conf t
interface fa0/1.11
interface fa0/1.22
3) If your interface fa0/1.33 is only 2 Mbps then you can do this:
conf t
ip access-list extended LIMIT_2MB
permit ip any any
class-map match-any LIMIT_2MB
match access-group name LIMIT_2MB
Policy-map LIMIT_2MB
class LIMIT_2MB
  police 2000000 conform-action transmit  exceed-action drop
interface fa0/1.33
service-policy input LIMIT_2MB
service-policy output LIMIT_2MB
Your config will look like this:
################ LEAVE ACL AS THEY ARE - THEYRE LIKE THIS FOR FUTURE REQUIREMENTS
permit ip any any
permit ip any any
permit ip any any
################ TO LIMIT FOR 2 MB
class LIMIT_2MB
################ TO LIMIT FOR 10 MB
class LIMIT_10MB
################ APPLY SERVICE POLICY TO INTERFACES
interface fa0/1.11
interface fa0/1.22
interface fa0/1.33
And this should be it. I hope this is more clear for you. Just remember to take out the rate limit commands as they arent doing much for you.
Hope this helps
I created MY_NAT for your NAT statements only.
I created LIMIT_10MB specifically for your 10MB limit policy
I created LIMIT_2MB specifically for your 2MB limit policy
These are separate ACL's used for different things. The NAT statement should be:
ip nat inside source list MY_NAT interface GigabitEthernet0/0 vrf Client-1 overload
It is only to make it visably clear and more defined as to what the Access Lists are used for, hence the names I used
MY_NAT is for NAT
LIMIT_10MB is for limiting to 10MB in the service policy etc.....
Hope this makes things clear.
14 Replies 14
Bilal Nawaz
Hope this helps
Thanks Bilal,
by the way here's my answer on your questions:
answer: Ip route vrf Client-1 0.0.0.0 0.0.0.0 121.97.65.61 global
is in way ? with the word global at end.?
______
answer:
router port:
switch port:
interface Vlan5
they have diff ip .61 on router & .62 on switch
____
answer:
Switch:
Router:
________
answer:
this is existing switch, and im afraid to change on this
It seems like you may be trying to implement two different solutions. One is router on a stick. The other is just simple routing. Was there a specific reason for using the VRF's? We could make it really easy for ourselves without the use of VRF's :-)
If I get this straight, you have two clients - you want to limit their bandwidth. And you dont want them to be able to talk to each other?
I assume this is the reason for the VRF? If so, then I can try to give you a fairly simple solution.
yes, that's i want,
my specific reason i config vrf's overlapping address, after i implement vrf's no overlapped happen and also sub-interfaces for bandwidth limiting and saving ports
on existing switchcore is working properly and function perfectly
in the other hand, i create another network using another cisco router 2911 and i use the existing switch core cause have 8 orts available,
on this, i need to workout router 2911 -> switchcore -> client's
with the bandwidth limiting DL & UL, cannot see each other, and can use public ip's for there individual server's implemented
can i request your simple solution as you said earlier then i try to implement
interface fa1/11
switchport
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
duplex full
speed 100
switchport
switchport
switchport
switchport
switchport
SW1#show vlan
R1#show run
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf client-1
rd 1:11
ip vrf client-2
rd 2:22
ip vrf client-3
rd 3:33
ip vrf client-4
rd 4:44
ip vrf client-5
rd 5:55
ip nat outside
duplex auto
speed auto
no ip address
speed 100
full-duplex
ip nat inside
ip nat inside
ip nat inside
ip nat inside
ip nat inside
no ip address
shutdown
duplex auto
speed auto
permit ip any any
R1#show ip route
R1#
INTERNET#
U.U.U
R1#
So in summary
Hi Bilal,
im on leave, as soon as possible i do it on my network
hoping your positive response is on my side until the network running perfectly and i wish you part of it
i rate correct answer after applying the commands
thanks
Hi Bilal,
It work great smooth and perfectly now i can surf on internet on existing switch i have
however, i have another problem, in bandwidth,
here's my config:
cisco standard burst in bytes , however
if test my speed. it booms right away more than 10Mbps
i want it to be, UL and DL for 10Mbps
did i miss something? or should i put:
bandwidth 10000
ip nat inside
conf t
permit ip any any
class LIMIT_10MB
Hope this helps.
Hi Bilal,
i follow your config and i did is this:
class-map match-any LIMIT_10Mbps
match access-group name LIMIT_10Mbps
policy-map LIMIT_10Mbps
class LIMIT_10Mbps
ip access-list extended LIMIT_10Mbps
permit ip any any
permit ip any any
ip nat inside source list LIMIT_10Mbps interface GigabitEthernet0/0 vrf Client-1 overload
interface GigabitEthernet0/2.10
no rate-limit input 10000000 3750000 3750000 conform-action transmit exceed-action drop
no rate-limit output 10000000 3750000 3750000 conform-action transmit exceed-action drop
___________
there's no command like this in my router 2911.
only have service-family
should i delete this:
1.
permit ip any any
and
replace this:
permit ip any any
or
i can leave it and add this new access-list limit_10mb
______________
2.
how to deploy the LIMIT_10MB on every each sub-interfaces?
ip nat inside
ip nat inside
___________
3.
And if / what if my:
interface FastEthernet0/1.33 is only 2Mbps, then how to solve this?
___________
can you give me config on:
interface FastEthernet0/1.22 - 10Mbps
interface FastEthernet0/1.11 - 10Mbps
interface FastEthernet0/1.33 - 2Mbps
in access-list:
should leave this two.. or it must only 1 of them remain coz of conflict
conf t
interface fa0/1.11
interface fa0/1.22
conf t
permit ip any any
class LIMIT_2MB
interface fa0/1.33
permit ip any any
permit ip any any
permit ip any any
class LIMIT_2MB
class LIMIT_10MB
interface fa0/1.11
interface fa0/1.22
interface fa0/1.33
Hope this helps
how about this i just confused:
which i should use ? MY_NAT earlier you create and the new one is LIMIT_10Mbps for overloading
MY_NAT is for NAT
Hi Bilal,
i would like to say thank you very much for solving this problem
once again many thanks
all config's are smooth and perfectly running
You're welcome :-)   - Thank you for your kind comments and helpful ratings! Happy to help.
