SF 300 Voice and data VLAN Configuration on port
interface fastethernet4
 storm-control broadcast level 10
 port security max 10
 port security mode max-addresses
 port security discard trap 60
 spanning-tree portfast
 spanning-tree bpduguard enable
 macro description ip_phone_desktop
 switchport trunk allowed vlan add 400
 switchport trunk native vlan 10
 !next command is internal.
 macro auto smartport dynamic_type ip_phone_desktop
WE NEED TO ADD THE BOLD COMMANDS ALL OTHERS ARE DEFAULT.
we have to configure these two only for allow both data and Voice vlans
in some post i saw there is a command voice vlan-id  <vlan-id> but in my case this not work. id ont know why. but my above solution is 100% working.
dhanushka_
This is really help full thanks for the information.
Here are the rules for VLANs ..
When you set the switch port  interface to  access mode, a switch port can be only a member of one untagged VLAN
When you set the switch port  interface to trunk mode, a switch  port can be a member of only one untagged VLAN but also a  member of many Tagged VLANs.
But what you seem to be trying to achieve is use ports 1-7 as  unprotected or open  ports  for  ports 8-24 within the switch.
Really seems like something called  Priveate Vlan Edge PVE, whereby protected ports will only forward packets to unprotected ports and not other protected ports. .
Here is the definition found in the help text from within the switch.
  • Protected Port—Select to make this a protected port. (A protected port is also referred as a Private VLAN Edge (PVE).) The features of a protected port are as follows:
    • Protected Ports provide Layer 2 isolation between interfaces (Ethernet ports and Link Aggregation Groups (LAGs)) that share the same Broadcast domain (VLAN).
    • Packets received from protected ports can be forwarded only to unprotected egress ports. Protected port filtering rules are also applied to packets that are forwarded by software, such as snooping applications.
    • Port protection is not subject to VLAN membership. Devices connected to protected ports are not allowed to communicate with each other, even if they are members of the same VLAN.
  • Both ports and LAGs can be defined as protected or unprotected. Protected LAGs are described in the Configuring Link Aggregation section.
  • So my steps were
    • So I am wondering if you really need to configure alot of vlans.
    • make ports 8-24 protected port
    • Save the configuration
Clicked to tick the option to protect switch port 8.
That's what we end up with , port 8 is now protected.
Now lets copy the settings from port 8 to ports 9-24, see the circled area below.
now will in the ports you also wish to protect.
Now ports 8-24 are protected ports.
Hosts on these ports will only be able to communicate with hosts on ports 1-7 or  switch port 24 onwards, in the case of my switch.
Make sure you save your configuration.
